Old 01-28-2013, 05:04 PM   #1
CWButler
Fan#: 109200
What I Drive: 2002 Yellow ZX3
FF Reputation: 1 CWButler Good Standing Member
Coolant leak below Thermostat Housing
2002 ZX3 with 2.0L Zetec. Leaking coolant below Thermostat housing. Replace the hose. Also replaced Thermostat housing and thermostat including gasket for each. Still leaking as soon as i fill it with coolant. Any Ideas???
CWButler is offline
Fan#: 1
Old 01-30-2013, 05:13 AM   #2
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
FF Reputation: 0 tmittelstaedt Newbie
What part did you replace it with? The dealership part or the Dorman kit that has everything all in one - housing, thermostat, etc. - or the $18 cheap aftermarket housing only? Did you use a new gasket or the existing one? What did you torque the bolts to?
Take the housing off and use your fingers and feel around on the head. Is it smooth or bumpy? If bumpy make sure all gasket or other material is cleaned off. If all gasket material is cleaned off and it's pitted, then you have a problem.
One possible solution to a pitted cylinder head is to dispense completely with the housing to head gasket. Instead you take the housing and fill the gasket channel up with epoxy as well as the other flat areas on the housing. Then sand, file or mill the housing area smooth and use a regular flat gasket, and a -lot- of gasket sealer. Somewhere there's a writeup by someone who did this and he said it works well. You can use your old housing for this.
tmittelstaedt is offline
Old 01-30-2013, 05:26 AM   #3
CWButler
Fan#: 109200
Thanks, so I found out what I thought was the thermostate housing that I replaced was actually the hose connetion (Neck) that bolts onto the housing and holds in the Thermostat. after replacing the actual housing, everything is working great.
CWButler is offline
