IAC Problems. surpercharged. help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2013, 01:04 PM   #1
Michael_Price1990
Michael_Price1990's Avatar
Fan#: 101650
What I Drive: 2003 Yellow SVTFocus. Infiniti FX35
FF Reputation: 1 Michael_Price1990 Good Standing Member
Alright i am having some issues and i was told to post here. heres a link to my problem. im pretty sure its a bad IAC though. what do you guys think? and can i drive without it for now untill some warmer weather comes around to fix it?
http://www.focusfanatics.com/forum/showthread.php?t=307605
- Michael Price
2003 SVT Focus
205+ HP
JRSC
Michael_Price1990 is offline
Old 01-27-2013, 01:41 PM   #2
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Seems like a vacuum leak, do some leak tests until you find it. Who's tuning it? Did it idle before?
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 01-27-2013, 05:39 PM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
definitely sounds vacuum, im guessing around pcv area
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 01-27-2013, 10:38 PM   #4
Michael_Price1990
Fan#: 101650
Well it was running fine untill recently. i was going to get a tune with tom after i get my tax return hopefully soon. i installed the supercharger a few months ago and it has been driving and idling fine untill recently. and as i stated when i unplug the IAC it idles fine. where should i check for a vacuum leak? any diagrams online i can look at? i think ive checked all the vacuum lines. at least all the ones i messed with when adding the supercharger
- Michael Price
2003 SVT Focus
205+ HP
JRSC
Old 01-28-2013, 11:54 AM   #5
Mother Focus
Fan#: 73292
Leak can be almost anywhere, there is the smoke test but what I do is fix a piece of a tire tube over the air intake (turbo in my case) leaving the fill valve exposed so I can blow some air in with a compressor(3-4psi)use a spray with soap and water like trying to find a hole in a tire. Spray over throttle, IAC, vaccuums, intake manifold, break vac hose, etc. the iac might bubble some but it's normal, not on the flange though.
PTE 6262CEA
Old 01-28-2013, 07:00 PM   #6
Michael_Price1990
Fan#: 101650
Well you guys were on the right track. luckily i asked or i would have removed the whole supercharger and IAC for no reason. i looked over the vacuum lines with the car off and i made sure there were no breaks or loose connections. and then i started it a few times for a bit and felt for leaks. i was about to give up when the lines finally warmed up a bit and would collapse and suck themselves closed at idle. went to auto zone and got some stronger lines for the vacuum lines and it seems to be idling at 800-1000 again like it should!
i replaced most the vacuum lines with the install of the supercharger but the instructions said to use several of the original lines so i did. should have known better. it was the bigger line going from what use to be the side of the air box down to the bottom driver side of the engine. the supercharger added some distance causing a kink in the line.
Thanks guys, if you wouldn't have told me vacuum problems i would have wasted a whole day off at my dads place on my back.
- Michael Price
2003 SVT Focus
205+ HP
JRSC
Old 01-28-2013, 07:13 PM   #7
Mother Focus
Fan#: 73292
Infamous PCV line, always effing up!! Glad you found it!
PTE 6262CEA
