| Car Audio, SYNC, MyFord Touch & Electronics The Forum for the Ford Focus audiophiles. The place to chat about automobile sound systems, security systems, or show off your I.C.E.! Sponsored By: GT Sound Control
#1 | ||||
Aftermarket radio turns off when accelerating
I installed an aftermarket radio last week. I've wired other radios in older cars of mine and havent had any issues. The problem with this one is that I had to splice the stock harness to wire in the new one. When I was trying to figure out which were the front and rear speakers there was a spark and I blew a fuse or two which I have already replaced.
The problem I am having is when I accelerate the radio turns off and will come back on later. I only have this problem when it is in gear, I reved the engine when in park and the radio was fine. From searching the forum I found that it could be bad coils or alternator but I installed new coils earlier today and my alternator is putting out about 14.8V. I'm going to look through my fuses and see if anything else blew but after that I don't know where to go. Any suggestions would be greatly appreciated! Thanks, Tim |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
Captain TMI
Moved to Car Audio and Electronics, because these guys are more familiar with issues caused by aftermarket installations. General Technical Chat is for maintenance issues on stock vehicles or un-modded parts.
FYI: you can use a 9v battery on the speaker wires to figure out location- you'll hear a pop in the speaker when both wires are connected. It's a lot better than blowing fuses. I also highly recommend purchasing Metra adapters online. If you look around, you can find those a lot cheaper than Best Buy or install stores. I think I paid $6 for the last one I used. It takes out the guess work and screw-ups with wiring. Good luck, and thanks for posting!
Be eclectic. ---The Complete How-To Archive-- Moderating everything now, let me know if I can help.
#3 | ||||
Thanks for the help. I looked online for adapters but its some weird off brand radio that my friend gave me, I couldn't find anything. It has a DVD player in it that is supposed to be run to the e-brake but I just grounded it. That potentially could be giving me the problems? I checked the fuses and didn't find anything.
#4 | ||||
FocusFest Event Team
first off please don't use a battery to test for speakers; you only use them to test phase. if you get the wrong wire you can cause damage or possibly set off an airbag and injure yourself (i've seen it happen). Always use a meter to test wiring. voltage for power wires and resistance for speakers.
do you know what wires you connected to? in the ford harness there are two wires that will appear to be a ground if not tested properly and can cause weird reactions if connected to the wrong one. i do have schematics on what the stock wiring is for comparison. also what brand and model is the unit you are using? certain ones have different non-cea wiring colors and can be easily confused and mixed up. grounding the parking break wire shouldn't cause any issues. also the adapter you were looking for is one that will connect to the car's factory harness and have open ends that you can then splice to the aftermarket headunit's harness.
2013 F150 4x4 SCrew XLT 5.0L Midwest Crew #22 Official FocusFest Event Planner
#5 | ||||
I'd have to look at the car to know what wires are actually connected to the power. I went through with a DMM and tested all the wires for voltages, I suppose I could have done a continuity test on the speakers as well (did not think of that at the time).
I'm driving a 2001 ford focus SE 4 door sedan I know the serpentine belt is slipping, especially when its raining/snowing it will squeel more. The radio will cut out when it starts to squeel and comes back once it stops. I know that is part of the issue, but I'm not sure why the radio cuts out when I come to a stop. I replaced the belt but I noticed the tensioner wasn't smooth when I was loosening it. I'm going to try to grease the tensioner or just replace it and go from there. Is it possible the belt is slipping even if there is no noticeable squeel? |
#6 | ||||
Replaced the alternator after getting it tested at Advanced. When I reconnected the battery I noticed it was corroded, so much that the car was actually having electrical problems (wouldn't start and lights were dim). I have cleaned the terminals. I also but a new tensioner on the serpentine belt but still having problems with the radio. I have been getting shocked a lot by the door jam getting out of the car. Given it is winter and you tend to get shocked more in the dry air, but could it possibly be a ground?
Any help is appreciated! |
#7 | ||||
after getting a test at advanced auto, there was an alternator problem. I replaced the alternator and got it retested. The new alternator is perfect but appearently there is a power drain.
I do not know much about drain tests, but it read 20.67A. I figured I would start with checking grounds. Does anyone know where the ground for the radio actually goes to on the car? |
| Thread Tools | |
| Display Modes | |
