No 4th gear - Page 3 - Focus Fanatics
Old 02-19-2013, 08:38 PM   #21
amc49
Fan#: 96610
FF Reputation: 19 amc49 Great Standing Member
Luck...........you should probably know that Ford strongly recommends the trans cooler be changed when this type of wear occurs, often the cooler stops up and the return to back of the end cover then slows down to a trickle to wear the cover out. The cooler is supposedly not cleanable, the design of the inside of tubes stops it from flushing clean of trash settled in it.
amc49 is offline
Old 02-20-2013, 10:24 AM   #22
Endless
Fan#: 109123
What I Drive: 2002 protege 5
FF Reputation: 1 Endless Good Standing Member
Thanks amc, i did read about that in one of the ford manuals. The mazda cooler looks a bit different than the ford cooler, but is probably similar internally. The mazda manual says to flush the cooler so I flushed it backwards and forward with mineral spirits and compressed air and the flow was normal. I will research the mazda cooler more and price out a replacement.
Thanks again for all of your help!
Endless is offline
Old 02-20-2013, 08:36 PM   #23
amc49
Fan#: 96610
There you go. Just putting it out there. I would have done same thing, if flow seems good enough the old one would most likely be going right back on car. I would have soaked it for a week in acetone, if that doesn't break trash loose nothing will or none there. Them factory boys don't care about recouping parts since they don't get advantage from it. I save/reuse every part I can. I blew up a CD4E on a Contour, common on them with the sorry engineering, one drive shell I reused looked like a bomb went off inside it (actually did in a way), it works fine some 6 years later. If you saw that part you'd laugh....
amc49 is offline
Old 02-21-2013, 01:57 AM   #24
Endless
Fan#: 109123
Dealers love throwing new parts at cars. It saves them time and makes them money.
I've learned over the years that alot of the parts I've replaced bought me little more than piece of mind over re-using the old parts with a thorough cleaning and inspection. Its amazing the service life you can get out of internal parts/ bearings even when non-critical areas are damaged. Theres a certain satisfaction i get out of reusing old parts and saving $$$.
Thanks again for all if your help!
Endless is offline
Old 02-22-2013, 05:59 AM   #25
amc49
Fan#: 96610
X2 there brother...........
amc49 is offline
Old 10-07-2013, 05:41 PM   #26
S2FocusZX3
Fan#: 119600
What I Drive: Gunmetal
FF Reputation: 1 S2FocusZX3 Good Standing Member
I know this thread is a little old, But I have a 2000 Focus ZX3 It has about he same issue. It will shift 1st and 2nd fine but when it tries to go from 2nd to 3rd it will just go from 2nd to neutral and it revs up and doesnt go anywhere. 1st and 2nd work great no slippage.
I was wandering if anybody could link me to the part he replaced or show me a pic. Id like to just replace that if its the issue.
also I have the DOHC and trans code is PVAC XS4P-DF
S2FocusZX3 is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
