Svt stalls in neutral? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2013, 03:34 PM   #1
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
What I Drive: 2013 Performance Blue ST
Points 1,170, Level 18
Points: 1,170, Level: 18 Points: 1,170, Level: 18 Points: 1,170, Level: 18
Level Up 70% Completed
FF Reputation: 1 LiciouzSVT Good Standing Member
Buy-Sell-Trade Rating: (6)
Okay I am pretty mechanically inclined. My dad was a mechanic in the military for over 20 years and has blessed me with the ways of the wrench. I love my car to death but it has really been aggravating me lately. Occasionally, when coming to a stop the rpms plummet and it stalls. After doing some research I cleaned the MAF, replaced the alternator and the pigtail, replaced the serpentine belt, the crank pulley, spark plugs, wires, coil pack, coil pack pigtail, o2sensor and I had the car smoked with absolutely no vacuum leaks. This car has just left me baffled. Currently the only engine mods are ORP, borla cat back, and toms tune. The car just rolled over 66,000. If you have any ideas I could really use them. I would like my car to just run with no problems for a week. Is that too much to ask for?
2003 Screamin' Yellow SVT - Wrecked
2004 Silver SVT- Sold
2013 Performance Blue ST- BEASTY
LiciouzSVT is offline
Old 01-26-2013, 03:53 PM   #2
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 7,994, Level 60
Points: 7,994, Level: 60 Points: 7,994, Level: 60 Points: 7,994, Level: 60
Level Up 22% Completed
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Have you inspected the IACV (Idle Air Control Valve)?
"I'm gonna sing the doom song..."
Mile30 is offline
Old 01-26-2013, 04:07 PM   #3
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
You know what I have not. How do I know if it's bad? Just a side note. 90% of the time it runs perfectly just when coasting in neutral or comepletly stoping it stalls. It only stalls maybe once or twice a week but it's enough to be annoying.
Old 01-26-2013, 05:51 PM   #4
Mile30
Mile30's Avatar
Fan#: 74686
The EGR and normal operation send burnt/spent gasses back through that portion of the intake. Carbon buildup is normal. Excess amounts of it restrict the normal flow of air; causing the engine to 'stumble'. If you want to be safe, get sensor-safe throttle body cleaner. If you are really ballsy, remove the part (if you find a lot of carbon)... and do not use brushes or scrub the stuff off! Let it dry completely before starting the car to make sure.
I'm gonna look this process up in the shop manual...
If you leave it on the car, do the job with the car running. The car will bog down a bit as the chems are burnt and passed, just stop spraying.
Mile30 is offline
Old 01-26-2013, 05:53 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
SVT's do not have a EGR valve. Try cleaning the IAC though as it can get grimy from oil vapors over the years.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 01-26-2013, 05:55 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 53%
Also moved ya to the Technical Chat area for more suggestions since your having a technical problem.
Moderator for
Technical Chat
Old 01-27-2013, 12:27 AM   #7
CharlieO
Fan#: 100963
What I Drive: 2003 Black Svt
FF Reputation: 1 CharlieO Good Standing Member
My car did this but only comeing down from high speeds and i did not have a code for it but i got a new tps and it cleared up
CharlieO is offline
Old 01-27-2013, 01:50 AM   #8
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,712, Level 78
Points: 14,712, Level: 78 Points: 14,712, Level: 78 Points: 14,712, Level: 78
Level Up 66% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 90 goinloco1 Excellent Standing Member
did this start after installing toms tune? if so get hold of him and let him know so you two can work on it.
try installing the stock tune and see if the problem goes away. if it does, then you know the idle needs work on toms.
if it doesn't, then it's either the iac or the tps.
goinloco1 is offline
Old 01-27-2013, 02:17 AM   #9
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
Alright thanks everybody! I was begining to loose hope. I'll work on those things and keep everyone posted.
Old 02-08-2013, 07:43 PM   #10
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
Cleaned the IAC and the problem still persisted so I replaced it and all is good!!! I am a little mad that I replaced everything else but at least she is running perfect now!
