Focus 2003 Gauge cluster - Stop and reset - Focus Fanatics
Old 01-26-2013, 12:10 PM   #1
maggot26frank
Fan#: 109110
What I Drive: 2003
FF Reputation: 1 maggot26frank Good Standing Member
Hi,
When I'm driving my 2003 Ford Focus, sometimes the gauge cluster stop for like 2 seconds and then, all the gauges pointers go to the maximum and it comes back to normal. In 30 minutes, it did that to me 4 times.
Does anyone of you know how to fix that problem?
Thanks
maggot26frank is offline
Old 01-26-2013, 12:21 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 267 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
You should check your alternator output. We sometimes get this when the voltage regulator fails. Try the electronic odometer trick: key OFF, press and hold trip odometer reset button, turn key to ON (not ACC), continue to hold reset button until odometer reads [test]. Now each time you press and release the odo reset button you will scroll through one of 30 test functions until the key is turned OFF again. You are looking for the test function that reads [bat 12.1] or whatever your battery voltage is. Now start the engine without turning the key to OFF, and the odometer will show the alternator voltage. If that voltage is above 14.9V at any point, then you have a bad voltage regulator, and you will need a new alternator.
The other option is that the instrument cluster connector is loose. This one is less dangerous to anything. It could also be that the cluster itself is bad, but I'd bet on one of these 2 first.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
