Changed bad coil pack car still won't start? 2002 focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2013, 10:42 PM   #1
Lovelyvanity
Lovelyvanity's Avatar
Fan#: 109000
What I Drive: 2002, blue, focus zx3 5speed
FF Reputation: 1 Lovelyvanity Good Standing Member
Question Changed bad coil pack car still won't start? 2002 focus
2002 ford focus auto 2.0l SOHC
Car will not start seems like its not getting spark. Checked timing and fuel pump its fine replaced battery, plugs, crank positioning sensor, and coil pack. (As you can see in the picture #4 appears to be burnt on old and there's cracks on side.)
Lovelyvanity is offline
Old 01-25-2013, 11:28 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Crank or cam sensor?
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 01-26-2013, 12:20 AM   #3
Lovelyvanity
Fan#: 109000
Just replaced the crank sensor before the coil pack earlier today.
Old 01-26-2013, 12:33 AM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
I assume engine spins but won't catch.
Test for spark usng a proper inline spark tester to confirm the presence or absence of spark. You should also check to see if you have 12V at the center wire of the coil pack connector.
It's an SPI so doing a commpression test should be high on your list of diagnostic tests. An engine with reduced or no compression on one or more cylinders will spin easily.
BC_ZX3 is offline
