"cylinder 1 misfire" code - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2013, 06:50 PM   #1
shabba
shabba's Avatar
Fan#: 44282
What I Drive: 2007 Silver ZX4 ST
FF Reputation: 1 shabba Good Standing Member
This code is present. We took out the spark plug cleaned it and set the gap
To the proper size. Car still runs like crap. Sputtering like crazy
Does this sound like it could be a bad valve? It's a ztec
Shabba...I could explain but you wouldn't understand
2001 CD Silver ZX3
shabba is offline
Old 01-25-2013, 07:17 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
P0301?
Was the back strap blued? Did it have a thin black residue that was difficult to get off? Was there any red on the porcelain inside the combustion chamber?
It could be a bad plug wire or coil. You'd have to do a compression test to see about the valve, but the spark plug would've had fluffy, thick, wet black residue on it.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-25-2013, 09:08 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,402, Level 75
Points: 13,402, Level: 75 Points: 13,402, Level: 75 Points: 13,402, Level: 75
Level Up 38% Completed
Forum Activity 99%
As whynot hinted, just what the plug looked like B4 being cleaned is critical information for diagnosis.....
(so is a compression check)
As to "guesses", the coil and it's connector pigtail are common issues - followed by plug wires & their connections. "Cracking" of the coil, especially in the base area that can only be seen after removal, is indicative of an issue there. Inspecting the coil connector & it's wiring is always a good idea on these, there's a reason a replacement "pigtail" is available from Ford....
Speaking of "tests", I like to do a quick check for spark with a neon spark tester, either an in-line model or the cheap & quick AC brand pocket pen tester that you only need to hold to the wire to see if you have a good jolt of electricity moving through it!
Luck!
sailor is online now
Old 01-26-2013, 05:47 PM   #4
jackdangle
Fan#: 107885
What I Drive: 2000 Toreador Red ZX3
FF Reputation: 1 jackdangle Good Standing Member
Had the same thing happen to me. Swap the #1 and #2 plug wires (on the coil pack too). If the code is now on #2, its a bad wire.
jackdangle is offline
Old 01-26-2013, 08:11 PM   #5
rotarypwr
rotarypwr's Avatar
Fan#: 107786
What I Drive: 88rx7 85rx7 02zx3hatch w/ roush
FF Reputation: 1 rotarypwr Good Standing Member
Another way is since its a waste spark coil you can swap 1 with 4 at coil and see if miss moves to 4. If it does its the coil.
rotarypwr is offline
