SVT Timing Belt Change? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2013, 05:40 PM   #1
2000Sr
Fan#: 62447
What I Drive: 2004 svt eap pitch black zx5
FF Reputation: 1 2000Sr Good Standing Member
I had a zx2, which had the VCT on the exhaust side, I have changed timing belts on the cars with ease, I would rotate everything with the factory belt on to TDC set the bar in the back of the cams, and then remove the belt and re-install the new belt and tighten the adjuster.
My Question is, My SVT will need a belt shortly, my question is, could I rotate it all to TDC set the bar in the back and then remove the belt and re-install the new belt and tighten the adjuster?
2000Sr is offline
Old 01-25-2013, 06:13 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 01-25-2013, 09:13 PM   #3
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
If I am reading this correctly, you are assuming the car is on TDC when you turn the engine and lock the cams in place. All this does is make sure that the cams are locked in place. This does not ensure the that #1 piston is actual TDC. You really need to use a crank locking tool. Unlike the ZX2 zetec, the zetec in the SVT is an interference engine.
150mphzetec is offline
Old 01-26-2013, 06:40 AM   #4
2000Sr
Fan#: 62447
so let you propose this.
roll everything to TDC, install peg, install cam locking tool, remove timing belt, then re-install everything.
2000Sr is offline
Old 01-26-2013, 09:56 AM   #5
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,854, Level 25
Points: 1,854, Level: 25 Points: 1,854, Level: 25 Points: 1,854, Level: 25
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
Read this: http://www.dj-sures.com/GraphicFiles...%20Timing.html
And this: http://forums.focaljet.com/ford-svt-...ols-ready.html
The consequences of NOT doing it correctly are very severe, and very expensive! Good luck.
mainest is offline
Old 01-26-2013, 12:10 PM   #6
150mphzetec
Fan#: 77175
Points 389, Level 7
^^wut??
review the links in mainest's post. They will help explain the procedure. It is also in your best interest to install new timing pulleys as well
