Another Gear Rollover & Hotline Report - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2013, 06:50 PM   #1
scada
Fan#: 107778
What I Drive: 2013, Silver, Focus S
Points 310, Level 6
Points: 310, Level: 6 Points: 310, Level: 6 Points: 310, Level: 6
Level Up 20% Completed
FF Reputation: 1 scada Good Standing Member
So I brought my 2013 S to the dealer because it was making a noise in neutral that went away when you depressed the clutch pedal.
They diagnosed it as the gear rollover issue and wrote it is a 'normal characteristic of this vehicle'.
It goes on to say see Hotline Report # 106042769
Anyone know where I can get this hotline report?
scada is offline
Old 01-24-2013, 07:05 PM   #2
Squirlyjim
Fan#: 102801
What I Drive: Fords
FF Reputation: 1 Squirlyjim Good Standing Member
That is the report #between the tech and Ford you have to ask the dealer service if he will get a copy for you
Squirlyjim is offline
Old 01-24-2013, 07:05 PM   #3
scada
Fan#: 107778
Points 310, Level 6
Ok I looked at the paper work I was given and I have a copy of the Hotline Report. Apparently the report is where the tech called Ford for assistance. This is what it says:
'This noise is referred to as neutral gear rollover noise and it is also common for these transmissions as it is the MTX-75. It is common to any manual transaxle with a four cylinder engine.
Neutral gear rollover noise is a product of the gears in the transmission reacting to the normal firing pulsations of the four cylinder engine. This noise is usually more pronounced when hot or with the A/C compressor engaged. Disassembly of the transmission is not recommended as it will not reveal a concern.
Neutral Gear rollover noise is not detrimental to the duration of the transmission or the vehicle and no repairs are recommended.'
scada is offline
Old 01-24-2013, 07:07 PM   #4
scada
Fan#: 107778
Points 310, Level 6
Squirlyjim; Thank you for getting back to me. Yeah I looked thru the paper work that was given to me and found the report.
scada is offline
