Old 01-24-2013, 03:58 PM   #1
Lovelyvanity
Lovelyvanity's Avatar
Fan#: 109000
What I Drive: 2002, blue, focus zx3 5speed
FF Reputation: 1 Lovelyvanity Good Standing Member
Question 2002 ford focus won't start? Crank angle sensor or upstream oxygen sensor?
2002 ford focus lx SOHC.
I was driving my focus and randomly decided it didn't want to go anymore. Coasted to side of road and shut it off. Tried to turn it back on and it just sat and cranked. Fuel pump and timing belt is just fine. Next things to try are replacing the upstream o2 sensor up and down are bad and have been for months. Crank angle sensor and coil pack. Which could cause it most likely not to start and could randomly go out while driving like that? When I try to start the car it's a soft steady crank sound. Please and thank you!
P.s. took off the valve cover and look how gunked up it is. Def time to change the oil.
Lovelyvanity is offline
Fan#: 1
Old 01-24-2013, 06:03 PM   #2
Codreamn
Fan#: 102049
What I Drive: 2002 Black SVT
FF Reputation: 1 Codreamn Good Standing Member
Did it make any kind of noise before it died?
Codreamn is offline
Old 01-24-2013, 10:24 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
You have the Focus SPI engine before you do anything do a compression test there very bad to drop the valve seats and loose compression
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 01-24-2013, 11:13 PM   #4
Lovelyvanity
Fan#: 109000
None at all it didn't even shut off till I did. It was like all of a sudden the gas pedal didn't want to go down.
Old 01-25-2013, 10:26 AM   #5
Codreamn
Fan#: 102049
With what you said i would not start throwing parts at it, especially O2 sensors. There are ways to check or have checked things that will eliminate the guess work. A compression test would be something i would start with like Tom said, just because the nature of that engine.
Codreamn is offline
Old 01-25-2013, 06:31 PM   #6
Lovelyvanity
Fan#: 109000
Took the coil pack off.. Cracked all to hell. Just got a new coil pack and plugs
Old 01-25-2013, 06:59 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
I don't think that would prevent the gas pedal from going down, but yeah, it seems bad.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-25-2013, 07:37 PM   #8
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Let's ask the obvious question,
IS the gas pedal working properly now?
Moving the throttle body pulley properly?
(i always start with the "stupid" questions....)
Luck!
sailor is offline
Old 01-25-2013, 09:33 PM   #9
Lovelyvanity
Fan#: 109000
Luck!
Throttle was perfect after. Here's a pic of how #4 on the coil pack looked. Changed the coil pack crank position sensor checked timing changed plugs. Engine still first seem to be getting spark.
Old 01-25-2013, 09:59 PM   #10
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Seem to be getting?
"Seem to be" is a red flag for me, it's something that needs to be tested to a firm conclusion, yes or no.
There are tools to test for spark, yet the simplest is to take the plugs out then connect them to their wires & lay them on a grounded metal surface & crank the engine (helper needed) so you can look for the spark at the plugs.
The valve cover is NOT grounded (supported by rubber gaskets) so find another handy spot!
Jumper cables are great for this, though car size are a bit unwieldy....
Cheers!
sailor is offline
