No brake lights, turn signals, or hazards - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2013, 12:26 AM   #1
bazelightyear
Fan#: 100055
What I Drive: 2003 black SVT
FF Reputation: 1 bazelightyear Good Standing Member
Any ideas? I checked the fuses and they're all fine. When I try to turn on the blinkers there is nothing whatsoever. No light on the cluster, no clicky noise, nothing. Same with the hazards. The only brake light that works is the 3rd brake light. Is there a relay that controls all of these things together? And where would it be? I'm pretty sure the hazards and signals are related, but would the brake lights be a seperate issue? Any help is greatly appreciated. It's a 2003 svt by the way.
bazelightyear is offline
Old 01-24-2013, 12:39 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Could be the Hazard switch, all the turn signals go through that. I've had problems in the past with mine and it ended up being the hazard switch.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-24-2013, 12:43 AM   #3
bazelightyear
Fan#: 100055
Thanks for the quick response. Would the hazard switch have anything to do with my brake light issue?
Proud owner of the slowest SVTF in the world... Seriously.
Old 01-24-2013, 12:52 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
Maybe, it goes through that switch so I imagine that would be the problem since the turns don't work. I hope it fixes it, electrical problems can be a nightmare.
Moderator for
Technical Chat
Old 01-24-2013, 06:29 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Yes, brake lights go through the hazard too. If your rear tail lights, the ones that come on with the headlights (parking lights), are coming on, but not the brakes or turns, then that's likely to be your problem. If the tail lights are not coming on, then you are more likely to have a grounding problem.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 01-24-2013, 02:22 PM   #6
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
You can check to see if the switch is still plugged in tight. Remove one of the two center dash a/c vents and you can reach inside and push the connector on the back of the switch. This is a pic with the center console removed. This is not needed just to check the connection.
TerryB is offline
Old 01-24-2013, 02:42 PM   #7
bazelightyear
Fan#: 100055
Thanks a lot for the help guys. I checked the connection and it's fine. I'm gonna try to pick up a new switch today and I'll let you know if that does the trick.
Old 01-26-2013, 08:14 PM   #8
bazelightyear
Fan#: 100055
So I replaced the hazard switch and even the turn signal stalk, and still nothing. I'm completely stumped. Fuses are good, wires are good, connections are good, grounds are good... Is there any possibility that there's an issue with the bcm?
Old 01-26-2013, 08:22 PM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
Check the wires coming out of the body and into the hatch, those are known to get split from opening and closing the hatch and grounding out causing all sorts of weird problems. You'll have to pull the black boot back to see.
Moderator for
Technical Chat
Old 01-27-2013, 12:51 PM   #10
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Here is one way to do it.
How To: Hatch wiring repair
Be eclectic.
