Old 01-23-2013, 08:26 PM   #1
CBen
Fan#: 51928
What I Drive: 2003 ZTW
FF Reputation: 1 CBen Good Standing Member
factory or aftermarket?
I recently replaced the transmission mount in my FoFo. The original (or, what I assume to be the original) clearly needed it as the rubber was basically just flaking off. I replaced it with a Duralast (Autozone) part. This actually made the noise and vibration worse. Are the factory mounts really that much softer?
CBen is offline
Fan#: 1
Old 01-23-2013, 08:35 PM   #2
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
Factory mounts are always better, if you spend extra on the poly urethane mounts they wont necessarily last longer but they can take quite a beating.
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is offline
Old 01-23-2013, 08:45 PM   #3
pasta
Fan#: 62350
What I Drive: 2004 black eap svt
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (27)
factory way to go tousleyford.com
pasta is offline
Old 01-23-2013, 09:00 PM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
You probably need to do the passenger mount and the dog bone
There seems to a majority consensus (although there is one that says the no name mounts work) that the passenger side needs to be FORD OEM .
mikeeshaq is offline
Old 01-23-2013, 10:11 PM   #5
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
Aftermarket mounts will use like one rubber compound on everything they make and it will be hard as rock. Factory will often use different rubber compounds based on what engineering has shown to be the proper amount of damping for particular engine/chassis combinations. On the hydraulic mounts the aftermarket will be made very much shoddier with some new ones coming apart in weeks or days...............
Oh, and a lifetime warranty on those particular parts really means absolutely nothing, they are made so cheaply they actually plan on you coming back to get replacements which will fare no better. BTDT several times.
amc49 is offline
Old 01-23-2013, 10:19 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
When replacing one it's best to replace them all.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-23-2013, 10:23 PM   #7
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
FF Reputation: 20 xxMichaelAnthony Great Standing Member
Poly inserts.
http://effyeahsmallfords.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 01-23-2013, 10:34 PM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
I poly the lower one and leave the top ones. On a stock engine the vibes can be a bit annoying. I'd also recommend the Energy Suspension inserts over the Prothane ones.
Moderator for
Technical Chat
Old 01-23-2013, 11:39 PM   #9
xxMichaelAnthony
Fan#: 58459
I always hear Energy over Prothane. Why? Different compound? Firmer? Softer?
[HOONIGAN]
iTroll
Old 01-24-2013, 12:05 AM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
The ES mount has a lip on it to keep the mount from slipping out of the dog bone. I've also had a new Prothane mount split on me before which caused some damage to my car. Now I have a leaking PS rack and a bent exhaust. Though the exhaust was a tad too close to my PS rack to begin with but when the mount gave it whacked it good. I've had the ES mount last years before failing. Poly mounts do wear out they just take a lot longer to do it. Oh and the other Prothane mount I had is slipping out the mount. You can order the ES mount directly from ES for less than 25 bucks shipped. I have pics but can't post them due to my work internet.
Moderator for
Technical Chat
