Slow AC leak - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-23-2013, 07:46 PM   #1
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,065, Level 34
Points: 3,065, Level: 34 Points: 3,065, Level: 34 Points: 3,065, Level: 34
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Slow AC leak
My interval between topping off the R134a in the AC seems to be getting smaller....
I don't seem any signs of a leak (oily spots on AC hoses/connections) so, does anyone know if the AC system came with UV dye in it so I can look for a leak with a UV light?
thanks.
Ed
emsvitil is offline
Old 01-23-2013, 08:34 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
It should've. However, that has probably all worn off by now since you've been adding refrigerant.
I think you should go all the way. For one, the car is 12 years old, so the compressor is 12 years old. You have probably been losing oil, so you're lucky it's working at all. The orifice tube is definitely clogged up at this point, and that's probably exacerbating whatever leak you have. You can take a chance on the compressor- I know it's expensive- but I'd replace all the O-rings and the orifice tube before having it vacuumed and recharged. I might even consider replacing the accumulator- except that I remember that early Focis have an accumulator that is different and very expensive because you need a new hose as well. You might want to look into the parts and see what you need. What you really need to check, and be wary of damage on is the condenser. A small condenser leak is a big problem because the condenser is such an expensive and difficult part to replace. It's also one of the most likely places for a small leak because it's susceptible to road debris damage.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-26-2013, 01:00 AM   #3
emsvitil
Fan#: 50210
Forum Activity 2%
A can of R134a is cheaper.................
I'll first take a look with my UV light to see if I see anything.
If I don't see anything I'll then tighten the valve cores and replace the valve caps and see what happens........
Ed
emsvitil is offline
Old 01-26-2013, 01:23 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 99%
Whynot might shoot me for this comment...
But if you've been adding straight R134, maybe some of the "cheap stuff" that includes dye & oil next time - to add some back in so your UV light will work?
I KNOW adding oil, dye, and sealant isn't recommended, but if the original charge is getting low like he guessed..... maybe this once??
sailor is online now
Old 01-26-2013, 01:42 AM   #5
emsvitil
Fan#: 50210
Forum Activity 2%
I thought of that.......
Then I forgot.
Thanks for reminding me of that idea.
Ed
emsvitil is offline
Old 01-26-2013, 02:40 AM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Great Minds....
I think....?
Ha!
Old 01-26-2013, 12:31 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
I'd avoid stop leak, but do what you want. What happens is that when the system is discharged, the stop leak hardens up- whether it's inside or not. This KOs parts, and sometimes expensive parts. That's the danger of stop leak. If you get lucky, maybe it will do it's job and stop the leak for you- who knows.
Good luck!
Be eclectic.
Old 01-26-2013, 04:45 PM   #8
emsvitil
Fan#: 50210
Forum Activity 2%
Definitely no stop leak............
I've read horror stories all over the internet about AC stop leak.............
Ed
emsvitil is offline
