Overheating and no heat - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2013, 12:40 AM   #11
kimszoo
Fan#: 106993
What I Drive: 2000 Toreador Red SE
FF Reputation: 1 kimszoo Good Standing Member
Sorry, poorly worded. No the bottle was tipped slightly, leaning towards the engine at an angle. The coolant was fine yesterday, about halfway between minimum and maximum but the leaning bottle made the coolant slosh out the cap a bit, when it overheated I assume. The level was above max until it cooled a bit then was back to just below midway.
kimszoo is offline
Old 01-24-2013, 12:47 AM   #12
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Gotcha. So the coolant level is fine.
I doubt your heater core is the problem, although on certain cars, depending on how the cooling system is set-up, a plugged core can cause both your issues. I seriously doubt its that though, especially since you said you flushed it a while back.
If you are hearing a grinding sound from the water pump, I would start there. Even if it isn't leaking externally it can be failed. That bearing can fail, causing your noise, in some cases the impeller of the shaft can come loose (therefore not pumping much), and in some extreme cases the impeller can just rot away (doubt its that one..).
Before that though, I might check to make sure the radiator isn't plugged up completely. Disconnect the lower and upper hose and using your hand as a sort of seal around a garden hose, stick the hose in the upper neck and see how forcefully water comes out the bottom. Just to be safe.
jetrinka is offline
Old 01-24-2013, 12:51 AM   #13
kimszoo
Fan#: 106993
Thank you, I will do that first. Would be much nicer than changing out a water pump right now
kimszoo is offline
