Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Chassis
Brakes, Suspension & Chassis The place to go for answers on brakes, suspension, camber, alignment and more.
Old 01-22-2013, 11:51 PM   #1
murraypaultec
Fan#: 108946
What I Drive: 2003 grey ZX5
FF Reputation: 1 murraypaultec Good Standing Member
Better handling please....
I just aquired a 2003 Focus ZX5. It has 145k miles and tires that are OK, but not matched. Overall, it is in very nice condition. I am pleasently surprised with the engine performance, it is very quiet at idle and has a lot more pep than I was expecting. What I don't like is that it feels like it is all over the road. I am used to larger vehicles with bigger tires, but I thought this car would handle better than it does.
My desire is not to spend a bunch of money and be ready to go out racing, I just want a car that feels solid on the road. Is it possible to improve the ride and handling without turning it into a race-car-wanna-be and spend less than $500 on the parts?
murraypaultec is offline
Old 01-22-2013, 11:57 PM   #2
ToreadorFocus
ToreadorFocus's Avatar
Fan#: 100350
What I Drive: 2006 Dark Toreador Red ZX3
FF Reputation: 1 ToreadorFocus Good Standing Member
with that kinda money the best ur probably gonna get is a front and rear sway bar which would help alot but a coilover kit is gonna be ur best bet
ToreadorFocus is offline
Old 01-23-2013, 08:22 AM   #3
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
FF Reputation: 23 wrc_fan Great Standing Member
Age and miles will have a big impact on the car rides, and 10 yrs old and 145K miles is starting to get up there.
The two biggest bang for the buck items will be new dampers and a new set of tires. A new set of SVT dampers with the stock springs you already have could be an affordable option. Blown/worn dampers will lead to a car that feels like it can't hold the road.
Mismatched tires can lead for funky handling. Also, at that age, wheelbearings, ball joints, and tierod ends can start to go, adding to the handling issues. These items should be inspected.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 01-23-2013, 08:58 AM   #4
gondorian
Fan#: 105695
What I Drive: 2002 Ford Focus SE Wagon 5spd Zetec
FF Reputation: 7 gondorian Good Standing Member
I would say first off make sure your tie rod ends and ball joints aren't worn out. Those aren't too expensive or too hard to replace, and new ones can make a big difference in steering feel. Dampers are a good suggestion too.
gondorian is offline
Old 01-23-2013, 08:58 AM   #5
PDQEagle
Fan#: 9356
What I Drive: 03 Focus ZX3
FF Reputation: 11 PDQEagle Great Standing Member
it sounds simple, but check your tire pressure
If the tires are pretty well shot, replace
Make sure existing tires are all the same size
PDQEagle is offline
Old 01-23-2013, 11:38 AM   #6
murraypaultec
Fan#: 108946
I take it that "dampers" is another name for "shocks"? I have seen some kits with shocks, springs, and sway-bars for about $500. They all boast that they will lower the car 1/2", I wasn't looking to lower it, but I guess 1/2" is no big deal. I will also check out the tie-rod ends and ball-joints. It likely needs brakes too, so I may as well gather up all the parts and do it all at the same time.
Its a California car, so I shouldn't have much trouble wressling the parts off.
Thanks for the suggestions.
Old 01-23-2013, 11:55 AM   #7
gondorian
Fan#: 105695
When the shock is on the interior of the spring and they are both held together in one assembly it is called a strut and the shock absorber is more likely to be called a damper. (But all shocks work by dampening the movement of the suspension)
Old 01-23-2013, 12:02 PM   #8
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
FF Reputation: 10 mac.mogul Great Standing Member
I would recommend the SVT suspension kit. The "lowering" will be barely noticeable and the ride will be much more planted without being too firm.
Item number is M-3000-ZX3
$247 @ tousleyfordparts.com
And while you've got the suspension off I would recommend MOOG front end links and a full set of poly bushings.
That all together should run close to $500 and will feel like a brand new car without being a boy-racer.
2011 SES 5spd #006 >> SR #213
Join the cause! 3 Door Fords for America! facebook.com/3DRS4US
The internet is for finding an answer, not for finding ways to ask a question.
mac.mogul is offline
Old 01-23-2013, 02:29 PM   #9
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Yup, I like to use the term damper, that's what the part is doing, slowing down and controlling the speed of the suspension movement. Shock is a more common term, but not as descriptive (semantics really). A strut is a damper thats been designed such that it is a loaded link of the suspension. Struts are common on the front of most modern cars.
Anyhow, if you like, there used to be some kits available with just the SVT dampers (struts and shocks).
And don't call them dampeners, that would imply stuff is getting moist :P
Parking Lot Hero
wrc_fan is offline
Old 01-23-2013, 03:11 PM   #10
murraypaultec
Fan#: 108946
The car had the front sway bar links replaced last year, I guess if they were worn, the rest of the streering is pretty tired too. I like the kit from Moog, it is $225. That, along with the suspension kit that Mac suggested put me on budget of $500. Some new tires and a wheel alighment should make it feel better driving around town.
http://www.moog-suspension-parts.com...PackageDeal025
