finding the right fuse? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2013, 11:54 PM   #1
Heining17
Fan#: 98657
What I Drive: 2009 Blue Focus SE
FF Reputation: 1 Heining17 Good Standing Member
Hey guys,
I have my amp and sub set up working now... but not exactly how I want it. I have the remote wire tied into the power wire and I just use a switch.
So.. Im sick of this switch lol... Its just a pain in the ass, so I bought an add a fuse so I could just connect remote wire into the fuse box. I tried adding the fuse to "sync" and headlights. The sub is still constantly on even when keys are not in ignition. Am I using the wrong fuse or whats wrongs lol? I want it to turn on when car is on.
Heining17 is offline
Old 01-23-2013, 08:14 AM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
i'm assuming this is all hooked up to the factory headunit right? just wanted to make sure.
i'm not a fan of using fuse taps, but if you want to, try number 28 or 29. those two look like they are ign powered. i would personally recommend doing an inline fuse and tapping on to the acc wire from the ignition.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 01-23-2013, 10:17 AM   #3
Heining17
Fan#: 98657
I've never used an inline fuse before besides the power wire. I'm pretty new to this stuff, so that's why the fuse tap seemed like a good idea to me.. It was straight forward. Why is it that you don't prefer them?
Thanks for the reply!
Old 01-23-2013, 10:17 AM   #4
Heining17
Fan#: 98657
Also, this is all hooked up to main head unit lol
Old 01-23-2013, 10:20 AM   #5
Kipp
Kipp's Avatar
Fan#: 31300
they aren't the most secure connection and you run a higher risk of overloading a vehicle circuit or shorting something out if that metal hits something. that and to do it properly you need to make sure you hook up to the correct side of the fuse which not everyone does. if you get the wrong side of the fuse then you aren't actually using the fuse.
Midwest Crew #22
Kipp is offline
Old 01-23-2013, 12:01 PM   #6
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
This^
follow kipps suggestions here and do it the right way(=
It will save you alot of hassle in the future and you don't have to worry about it failing
Galatians 6:14
crice8 is offline
Old 01-23-2013, 01:32 PM   #7
Heining17
Fan#: 98657
Originally Posted by crice8 View Post
This^
Then what is the right way lol? So I tap into an accessory wire but which one? I tried taping in before but the amp still would stay on even without the keys in ignition.
Thanks again
Old 01-23-2013, 01:49 PM   #8
Kipp
Kipp's Avatar
Fan#: 31300
look for a purple/green wire from the ignition switch. that's the acc wire. use an inline fuse and solder on to the acc wire and run through the fuse then to you amp turnon
Midwest Crew #22
Kipp is offline
Old 01-23-2013, 01:50 PM   #9
Kipp
Kipp's Avatar
Fan#: 31300
i do always recommend to get a meter and test the wire before you connect to it as well. never know if it's different for some reason.
Midwest Crew #22
Kipp is offline
Old 01-26-2013, 10:47 AM   #10
Kurtsmith2013
Fan#: 108102
What I Drive: 08 focus titanium grey
FF Reputation: 1 Kurtsmith2013 Good Standing Member
Sorry for butting in can anyone tell me where the ignition fuse is on the 08 focus please, is it under the bonnet or under glove box?
Kurtsmith2013 is offline
