01 heater core. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2013, 07:51 PM   #1
iB Chunkyboy
Fan#: 105705
What I Drive: White 2001 Ford Focus LX 4DR Sedan
FF Reputation: 1 iB Chunkyboy Good Standing Member
01 heater core.
My friend owns a focus, hers in a 01 se. she has no heat, it must be the heater core. was wondering if anyone knew how to get it out and replace it?
help :] thanks. or other possibilities it could be, we flushed her system and put all new coolant in and still nothin
iB Chunkyboy is offline
Old 01-22-2013, 08:11 PM   #2
spike8807
Fan#: 74430
What I Drive: 2013 performance Blue ST2
FF Reputation: 1 spike8807 Good Standing Member
look into the thermostat before u go at the heater core much cheaper and easier to get to
spike8807 is offline
Old 01-22-2013, 08:12 PM   #3
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Check the temperature (heat/cold) control cable. If the heater core is hooked up and your car is getting up to operating temperature then this is most likely your problem. Do a site search for more info on how to bypass the heater control cable.
Good Luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 01-22-2013, 09:09 PM   #4
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
Modern heater cores rarely stop up, thinking they do is thinking locked into the past. The heater loop now runs all the time to keep sediment from clogging it, if heater clogged then radiator will be too. Rather than close off heater core water (that allows the sediment to stack up), most cars now simply open a closed airdoor to the heater core compartment. Meanwhile the core flows water all the time to keep trash from settling in it.
If you disconnect the two 3/4" hoses you'll find around the stat housing you can run a water hose into one and see if you get flow out the other, pick either one to use for inlet. Those hoses run to the core.
Dash must come out to replace core on these, it really sucks............other things? Stat if temp needle not coming all the way up, blower motor not working, air control doors not working right (the cable issue mentioned).
amc49 is online now
