Overheating/blown radiator hose - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2013, 06:30 PM   #1
LiquidOC
Fan#: 39029
What I Drive: 2003 Blue ZX5
FF Reputation: 1 LiquidOC Good Standing Member
I had a bit of an issue this morning, drove my kid to daycare and the big radiator hose that comes off the thermostat housing blew. Before this I was getting NO heat, and it was really really cold this morning. When I replaced the big radiator hose, I found that the part you guys call a coolant crossover tube is also cracked. How fscked am I? The radiator has fluid in it but doesn't seem to be leaking, I have ordered the new crossover tube. Thermostat and housing was replaced last year with OEM so I have a hard time believing that's what happened...I think something just froze somewhere due to a sub-par mixture of coolant. Please let me know what I should do to diagnose/fix this issue!
Here's what I plan on doing: Flush system with engine running to get all old coolant out while in heated garage or temperature outside is above 35 degrees farenheight, replace busted hose and crossover tube. Hope for the best?
LiquidOC is offline
Old 01-22-2013, 06:41 PM   #2
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,109, Level 34
Points: 3,109, Level: 34 Points: 3,109, Level: 34 Points: 3,109, Level: 34
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
You need to fill with pure antifreeze, not the 50/50 stuff.
After flushing, a lot of water stays behind.
Zetecs have a 6.1 qt capacity, so use 3qts of pure antifreeze after flushing.
Ed
emsvitil is offline
Old 01-22-2013, 10:18 PM   #3
LiquidOC
Fan#: 39029
If the 3 quarts isn't enough to fill the reservoir am I fine to start dumping in the 50/50 blend then?
Also, is there a better place to get the crossover tube than the stinkin' ford dealership? The closest one to me runs annoying ads lol
LiquidOC is offline
Old 01-22-2013, 10:25 PM   #4
emsvitil
Fan#: 50210
Forum Activity 2%
After the 3qts, go with water to fill to the line.
Then 50/50 to make up any slow losses.
Ed
emsvitil is offline
