TPS system gripes - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2013, 08:50 PM   #21
jsr72
Fan#: 97393
What I Drive: 2012 Focus SE
Points 151, Level 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Level Up 2% Completed
FF Reputation: 5 jsr72 Good Standing Member
Originally Posted by jeff_nc View Post
And will it change the behavior of waiting 20 miles before sounding the alarm?
Doubtful. Federal Safety standards permit up to twenty minutes of detection time before warning lamp illumination.
You can read some of the background with regards to detection time and threshold safety standard here.
Interestingly:
In its comments, Hyundai American Technical Center, Inc. / Kia Motors Corporation (Hyundai) provided yet another recommendation regarding low tire pressure detection time, stating that the time period for detection and verification of low tire pressure under the standard should be extended to at least 20 minutes. Hyundai stated that delivery frequency for data from the direct TPMS tire pressure sensor to the main control unit can take as long as three minutes, which is a function of Federal Communications Commission (FCC) requirements that limit signal transmissions and the capacity of the battery in the sensor. In addition, Hyundai stated that a number of transmissions may be required to correctly diagnose low tire pressure. Therefore, if a wireless data error occurs, Hyundai argued that the TPMS may not be able to gather sufficient data within the NPRM's proposed 10-minute time limit to assess the vehicle's tire pressures. Accordingly, Hyundai argued that the final rule should permit at least 20 minutes for low tire pressure detection in order to give the TPMS sufficient time to gather enough data to make an accurate assessment.
jsr72 is offline
Old 01-26-2013, 08:51 PM   #22
Bolto
Fan#: 101615
What I Drive: 2012 Plat White Ti
Points 505, Level 10
Points: 505, Level: 10 Points: 505, Level: 10 Points: 505, Level: 10
Level Up 10% Completed
FF Reputation: 2 Bolto Good Standing Member
Is this something my Ford dealership will do? And will it change the behavior of waiting 20 miles before sounding the alarm?
Yup, training the sensors will make the sensors operate correctly; your dealership can do it, and if you didn't get the wheels there, they might charge you for it.
Or you can do it yourself one of two ways:
1. Follow this thread and you may be able to train without a reset tool; however, it didn't work for me, and I ended up buying the reset tool: http://www.focusfanatics.com/forum/showthread.php?t=301692
2. This is the reset tool that I trained my sensors with; just search tpms reset on this forum and you'll come up with a bunch of thread on how to easilly do it: http://www.amazon.com/Motorcraft-TPM...cus+tpms+reset
Bolto is online now
Old 01-26-2013, 10:56 PM   #23
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
You do NOT need a special "tool" to train the sensors, I've done the procedure described in no 1 above (there is some YouTube videos that shows the procedure as well) on my F150, Focus, my wife's Escape and several friends newer Ford's (2011 Taurus, 2012 Fusion ) and it worked on all of them. If it didn't work for you, you missed a step, no biggie, try again. BTW, for those that missed the earlier threads on the subject, the sensors will automatically get picked up by the BCM in your car, which will turn out the warning light. However, if you want the car to know the position (location ) of each individual tpms, you'll have to "train" them as laid out in the procedure. Now your car will know which tire is low, not that it will actually tell you (well, at least US built models), other markets may have different BCM firmware that will not only display the offending low tire, but the pressure readings of all 4 tires.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 01-27-2013, 12:32 AM   #24
Bolto
Fan#: 101615
Dang, I wished I was just doing something wrong so that I didn't have to buy the tool, but I tried it half a dozen times and got tired of having to refill the tire up after the car kept telling me the training failed. A few other people couldn't get it to work it either, so I'm not the only one who was missing something. But it definitely doesn't hurt to give it a shot or two.
Bolto is online now
Old 01-27-2013, 10:28 AM   #25
jeff_nc
Fan#: 106534
What I Drive: 2013 performance blue titanium
Points 701, Level 14
Points: 701, Level: 14 Points: 701, Level: 14 Points: 701, Level: 14
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 1 jeff_nc Good Standing Member
Interestingly:
Wow, that's fascinating. Sadly, for me with mostly short trip driving, this makes TPMS useless. Sigh...
jeff_nc is offline
