Old 01-22-2013, 06:22 AM   #1
coldbear
Fan#: 78292
What I Drive: 2001 Burgandy ZXT
FF Reputation: 1 coldbear Good Standing Member
speedo sleeping
2001 Zetec has a bad habbit. As unit is driven,hot or cold, the speedo goes back to zero and engine power is reduced 10-15 percent. Any ideas on this prob.? Alltinator changed at 80,000. miles. Current mileage is now 170,000. Thoughts?
coldbear is offline
Fan#: 1
Old 01-22-2013, 10:22 AM   #2
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
FF Reputation: 17 nilskje Great Standing Member
If the odometer shows only --- when this happens, its the VSS going bad, it will certainly reduce the pwr , the ECU need seed info to work properly...
nilskje is offline
Old 01-22-2013, 07:33 PM   #3
coldbear
Fan#: 78292
Whuuuut??
VSS ???? Define please.
coldbear is offline
Old 01-22-2013, 07:50 PM   #4
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
vehicle speed sensor, on trans somewhere...........
amc49 is offline
Old 01-23-2013, 04:44 AM   #5
coldbear
Fan#: 78292
Thanks!
coldbear is offline
Old 01-23-2013, 05:32 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
You can test your alternator while driving. Since it went out at 80k, and now you have 150k- I'd suspect it.
Key OFF, press and hold odometer trip reset button. Turn key to ON (not ACC), continue to hold button until the odo display reads [test]. Release the button, now each time you press and release the odo reset button it will scroll through one of 30 test functions. It will remain in test mode until you turn the key off. The one you're looking for will read [bat 12.1], or whatever your battery voltage might be. Typically it is .2v lower than the reading you'd get from a meter between the battery terminals. Now, if you start the engine without turning the key off, you'll see your alternator voltage. You can monitor it while you drive in case you have problems with the voltage regulator putting out too much voltage. Anything over 14.9v is a problem. When the voltage regulator (built into the alt) dies off, you might see voltages as high as 50v from the alternator, but typically it's around 16v when things start to die off. Continued use of the alternator with over-voltage like this will cause the death of some electrical components giving you more problems to fix after the alternator goes out completely. IIRC, the battery light will come on for over-voltage problems like this once it reads over 16v.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-24-2013, 03:41 AM   #7
FocusGhia
Fan#: 94579
What I Drive: 2001 Ghia 1.6
FF Reputation: 3 FocusGhia Good Standing Member
Same here...VSS problem.
I have this for checking battery/alternator state. Gives constant readout from cigarette lighter plug. Not sure if you guys can get it in the US.
http://www.amazon.co.uk/Display-Digi...9020332&sr=1-9
FocusGhia is offline
Old 01-24-2013, 08:25 PM   #8
coldbear
Fan#: 78292
That is so freakin' cool,man. I had no idea that I could do a self test on my Focus. Thanks Whynot for the great idea. I also have a meter I use in my F-450 motorhome that tells voltage, oil pressure, water temps, and MPH. I use the test read port to plug the unit in and it reads untill the key is turned off. I'll try that test tomorrow.
coldbear is offline
