Old 01-21-2013, 09:52 PM   #1
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
FF Reputation: 1 #1fordfan Good Standing Member
battery or starter?
It's been cold here in Illinois the last few days. tonight when I got in my 2005 2.0 5 speed to start it and go to work,the engine turned over very slowly and then stopped turning over and then the starter made the noise it makes when it is turning but not contacting the flywheel. I quickly turned the key off,waited a few seconds and tried again. It turned over slowly but the engine did start and run fine. So what should I be looking to replace in the morning when I get off work provided it starts and gets me home?(supposed to be 3 degrees in the a.m.) How hard is it to reolace a starter on this car?
#1fordfan is online now
Fan#: 1
Old 01-21-2013, 10:11 PM   #2
GreenEnvy
Late for Dinner
Fan#: 8529
What I Drive: 13 stang, 02 svtf
FF Reputation: 90 GreenEnvy Excellent Standing Member
Battery is on it's last leg. How old is it? 5 years or more then its time to start looking at replacing before it leaves you stranded and costing more for a tow or jump on top of replacement. Also, if you go to advance or some where like that, they will put it in for free. then take it for a nice long drive to make sure it's fully charged and it gets a cycle through it. :)
And don't go with el cheapo battery, you get what you pay for.
If Guns Cause Crime, Mine Must Be Defective
GreenEnvy is offline
Old 01-21-2013, 11:07 PM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
FF Reputation: 8 emsvitil Good Standing Member
Make sure the battery connections are tight and corrosion free.
Ed
emsvitil is offline
Old 01-22-2013, 08:34 AM   #4
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
FF Reputation: 6 mainest Good Standing Member
Buy-Sell-Trade Rating: (7)
On both ends, IE. starter(+) and ground(-).
Generally, yes, but I had an EverStart Maxx installed, yesterday in my wife's Forester, free at Walmart, for $100. With a three year free replacement warranty. Almost all Walmart batteries are highly rated by Consumer Reports.
Your Focus should take a Group 40, or Group 96 battery. Installation is a piece of cake.
Good luck.
mainest is offline
Old 01-22-2013, 11:09 AM   #5
PDQEagle
Fan#: 9356
What I Drive: 03 Focus ZX3
FF Reputation: 11 PDQEagle Great Standing Member
In those weather conditions, I wouldn't even consider the starter as a problem until I checked the battery
First, make sure the connections at the battery are good, loosen and reseat by cleaning or twisting to reestablish a goog metal/metal contact. If you have a hydrometer, check it. It's pretty marginal and anything but an immediate start will show it as weak
Good luck
M Just replaced mine. It went 8 winters and was still in the lower "good" reading, but for $80, I want to be sure to get home from work
PDQEagle is offline
Old 01-22-2013, 01:03 PM   #6
SVTisRight4me
Fan#: 105772
What I Drive: 2004 Black SVTF 3 door#1009 in 2004
FF Reputation: 1 SVTisRight4me Good Standing Member
turn the lights on when its off and if the lights are dim its the batt. if u cant tell, keep them on and try to start if its harder than usual or the lights get really dim as u try to then its the batt.
-Baker
SVT Focus 2004 EAP 80k miles +. 1 of 128
SVTisRight4me is offline
Old 01-22-2013, 07:09 PM   #7
GreenEnvy
Late for Dinner
Fan#: 8529
Good luck.
Theres a reason everstart suggest replacement every 3 years...
