SVT Cranks but no Start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-21-2013, 09:36 PM   #1
sj9ers
Fan#: 95487
What I Drive: 2002 Silver SVT Focus
Points 32, Level 1
Points: 32, Level: 1 Points: 32, Level: 1 Points: 32, Level: 1
Level Up 64% Completed
FF Reputation: 1 sj9ers Good Standing Member
So my SVT Focus has had intermittent starting problems for a while now and now it just keeps cranking and wont start. Initially it would be hard to start sometimes and take a few tries but it would start. The car would also start and stay revved at around 4k rpms for a little bit until I drove around some. Also it would die at low RPMs once in a while while driving then I would have to start the car again. This would happen every so often but then it would go away. However it happened again 2 days ago and it took a while longer but it started. It was incident free last night and after I replaced the front O2 sensor today it won't start. I can hear the fuel pump come on but it just keeps cranking but won't start. I checked for spark and there was none. The coil pack, wire, and plugs have all been replaced within 9 months with all motor-craft parts. The wiring for the crank position sensor was fried so I replaced it but still no spark. There is also no codes. Any ideas of what else to check? Crankshaft Position Sensor? Camshaft Position sensor?
sj9ers is offline
Old 01-21-2013, 10:55 PM   #2
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,748, Level 78
Points: 14,748, Level: 78 Points: 14,748, Level: 78 Points: 14,748, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
check the wiring to the coil. not just at the plug, but all the way down into the loom on top of the tranny. fought this with a friends, replaced the coil wiring pigtail ($14 through ford) and still couldnt get the thing to act right or start all the time, or even stay running. ended up the wiring for the coil pigtail was messed up further down in the loom by about 5" than we had spliced.
first check your voltage at the plug and jiggle the wiring around to see if there is anything. if you don;t have voltage check the usual culprits first,,, fuses, etc. then start hunting down wiring.
goinloco1 is offline
Old 01-22-2013, 01:02 PM   #3
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
Crankshaft sensor. Can you check for codes?
paulg127 is offline
Old 01-22-2013, 04:34 PM   #4
sj9ers
Fan#: 95487
Points 32, Level 1
Already replaced it and nothing happened. And I checked for codes and none came up. I'm getting fuel though because I can smell it when I turn it over
sj9ers is offline
Old 01-22-2013, 04:42 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,517, Level 100
Points: 52,517, Level: 100 Points: 52,517, Level: 100 Points: 52,517, Level: 100
Level Up 0% Completed
Forum Activity 62%
Activity: 62% Activity: 62% Activity: 62%
Buy-Sell-Trade Rating: (28)
That doesnt mean you have enough fuel , need to check fuel psi and then spark at the plugs
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 01-22-2013, 04:58 PM   #6
sj9ers
Fan#: 95487
Points 32, Level 1
But I also used a spark tester and got no spark at the plugs
sj9ers is offline
Old 01-22-2013, 07:46 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
When you replaced the coil pack, did you inspect the plug-in connector? Pull on the wires going to the coil pack. Sometimes those are damaged. Also check back about a foot or so and look in the harness for damaged wires. I'd also check anywhere in that wiring loom that is near something hot like the EGR feed tube. We've had a few SVT owners that found damaged coil wiring back about 2' from the coil, but most of the time the wires will simply pull out of the connector. If that's the case, then you need a new pigtail. Any Ford dealer can get you the part.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
