2010 SES stock sound system question. - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 01-22-2013, 09:08 AM   #11
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
FF Reputation: 9 Kipp Good Standing Member
unless you go used "and i don't recommend it as you don't know for sure the condition) you will be hard pressed to find anything in that price range that's worth it. even a decent used amp will run $100 plus. if you're just looking for something simple that is cost efficient take a look at the infinity basslink. it's a self contained system (box, amp and sub in one unit) for around $200 or so.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 01-22-2013, 09:15 AM   #12
Lieblos
Fan#: 108845
What I Drive: 2010, Black, SES
FF Reputation: 1 Lieblos Good Standing Member
When I said $70-$100 I simply meant the price of each sub.
Lieblos is offline
Old 01-22-2013, 09:28 AM   #13
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by Lieblos View Post
Well, I do appreciation the suggestions. Also, I'm not looking for something to hit extremely hard I just want something that is a lot better than the stock speakers bass. I understand car audio is not a cheap thing but are there good priced subs that will get me a good bump for between $70-$100 each. Also what are some good speakers.
Also have you guys personally heard anything about this HU Pioneer-AVH-P2400BT
Also My focus doesn't have wheel controls or SYNC so which harness would I need. I was looking around and there are like 5 different types of wiring kits. Sorry for the overhaul of questions and you guys are being very helpful.
This is the correct harness you will need:
Axxess XSVI-5520-NAV
Not the cheap ones because the cheap ones will not retain your acc power. And this is the dash kit you will need:
Metra 99-5816
as well as this antenna adapter
Metra 40-CR10
Galatians 6:14
crice8 is offline
Old 01-22-2013, 09:38 AM   #14
crice8
crice8's Avatar
Fan#: 84830
Here ya go bud:
http://www.sonicelectronix.com/item_...o-REX10D4.html
They are 59.99 each and 175rms watts each, so this amp would push two nicely:
http://www.sonicelectronix.com/item_...NX1.1000D.html
it will do 475 rms watts if you wire two of the subs to it at a final impedance of 4ohms.
Galatians 6:14
crice8 is offline
Old 01-22-2013, 09:41 AM   #15
Kipp
Kipp's Avatar
Fan#: 31300
in all reality that harness can be done without. it will retain an acc output, but since you don't have the other features in the car you will be paying for things you don't need. you can just as easily get the basic harness and just run an acc wire to the car for that signal and save a bunch of money.
Midwest Crew #22
Kipp is offline
Old 01-22-2013, 09:43 AM   #16
crice8
crice8's Avatar
Fan#: 84830
Im going to guess you did that... how is your message center working out for you?
Galatians 6:14
crice8 is offline
Old 01-22-2013, 09:48 AM   #17
Kipp
Kipp's Avatar
Fan#: 31300
i actually have sync in mine and used the harness to retain it. however i have done installs in other 08-11 foci without sync using the basic harness and running an acc wire with no issues. the display just shows "ford focus" whenever the car is on. doesn't cause any issues.
Midwest Crew #22
Kipp is offline
Old 01-22-2013, 09:52 AM   #18
crice8
crice8's Avatar
Fan#: 84830
It allows you to retain your dimming function, speed sense, and data control signals as well as many other functions. while it does not cause issues to simply state ford focus on the display, you lose your temp display, direction, and any other data display features of our vehicle.
Galatians 6:14
crice8 is offline
Old 01-22-2013, 09:57 AM   #19
Kipp
Kipp's Avatar
Fan#: 31300
that is correct that you would lose those features, if the car has them in the first place. if all he has is the basic audio system then it's not really needed though. the data signal to the headunit is just for the accesory. speed sense doesn't work on aftermarket headunits unless it's a nav unit and even the newer ones of those don't need a speed sense input to work correctly like the older units did. dimmer is usually a seperate wire that is voltage based and also doesn't usually work properly with aftermarket units.
Midwest Crew #22
Kipp is offline
Old 01-22-2013, 10:00 AM   #20
crice8
crice8's Avatar
Fan#: 84830
Ok, good deal! Thanks Kipp for clearing that up for me(=
Galatians 6:14
crice8 is offline
