2010 SES stock sound system question. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-21-2013, 01:29 PM   #1
Lieblos
Fan#: 108845
What I Drive: 2010, Black, SES
FF Reputation: 1 Lieblos Good Standing Member
I was wondering where exactly the stock sub is and how to access it. I wanted to do a slight upgrade to the sub without the need of an aftermarket amp. My friend who use to do stereos said as long as I get the same OHM rating and roughly same wattage, I can just replace the stock and run it off the factory amp.
Lieblos is offline
Old 01-21-2013, 05:58 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
if you have one then it would be in is black enclosure on the side of the trunk. pretty obvious looking if it's there. not all of them (even the ses) came with one.
and changing out the sub isn't gonna sound or perform any better unless your happens to be blown.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 01-21-2013, 07:48 PM   #3
Lieblos
Fan#: 108845
May I ask how come replacing the stock wouldn't sound any better?
Lieblos is offline
Old 01-21-2013, 11:13 PM   #4
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
In the stock housing is what he means.... the stock housing is crap... so it is pointless to take out the stock speaker and put in a aftermarket speaker in the stock enclosure.... Now putting an aftermarket enclosure, sub, and amp in is a completely different story..
Galatians 6:14
crice8 is offline
Old 01-21-2013, 11:56 PM   #5
Kipp
Kipp's Avatar
Fan#: 31300
yes. the stock system is designed as a basic add on to the system. changing one part of it is like putting on a clean sock and expecting to be a better runner. if you really want a sound improvement you will need more than just the sub. also the factory sub is pretty low power and an equal replacement is not something that will perform to an expectation that would be desired.
Midwest Crew #22
Kipp is offline
Old 01-22-2013, 01:05 AM   #6
Lieblos
Fan#: 108845
Understandable, I was looking at a 2 10" with port box on crutch field I believe it was only $100 what are some recommendations for aftermarket speakrs and subs for someone that listens to mainly dub step and metal.
Lieblos is offline
Old 01-22-2013, 08:12 AM   #7
crice8
crice8's Avatar
Fan#: 84830
I would suggest re audio 10" SE-X Sub. I have had the 12" and 10" version and my one 10" SE-X hits harder than alot of peoples two twelve setups. SonixElectronixs has them on sell right now for $129.99. I dont imagine the two tens you found in a box for only $100 sound very good at all.
Galatians 6:14
crice8 is offline
Old 01-22-2013, 08:39 AM   #8
Kipp
Kipp's Avatar
Fan#: 31300
i have 2 10" alpine type E subs with the mrp-m500 amp and love it. hits hard when i need it to (ported box hit 141.8db at 50hz), but still have a crisp clean sound to it. and it's affordable. the subs retail for about $130 each and the amp was $200 i think.
Midwest Crew #22
Kipp is offline
Old 01-22-2013, 08:54 AM   #9
crice8
crice8's Avatar
Fan#: 84830
Here is a link to a reasonably priced solid setup for you:
Amp: http://www.sonicelectronix.com/item_...NX1.1000D.html
Subs: http://www.sonicelectronix.com/item_...o-SEX10D4.html or http://www.sonicelectronix.com/item_...o-SEX12D4.html
And I would highly suggest a box built to the exact specs of the speaker you choose. You should determine the speaker and amp you want to go with, then find a box for it. I'm all about doing car audio the right way as well as many other members here are. We have made plenty of our own mistake with cheaper brands and such.
Galatians 6:14
crice8 is offline
Old 01-22-2013, 09:57 AM   #10
Lieblos
Fan#: 108845
Well, I do appreciation the suggestions. Also, I'm not looking for something to hit extremely hard I just want something that is a lot better than the stock speakers bass. I understand car audio is not a cheap thing but are there good priced subs that will get me a good bump for between $70-$100 each. Also what are some good speakers.
Also have you guys personally heard anything about this HU Pioneer-AVH-P2400BT
Also My focus doesn't have wheel controls or SYNC so which harness would I need. I was looking around and there are like 5 different types of wiring kits. Sorry for the overhaul of questions and you guys are being very helpful.
Lieblos is offline
