Auto Trans. Broke? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-21-2013, 08:29 PM   #11
Pytcokid56
Pytcokid56's Avatar
Fan#: 87859
What I Drive: 2008 Silver Focus SE
Points 918, Level 16
Points: 918, Level: 16 Points: 918, Level: 16 Points: 918, Level: 16
Level Up 18% Completed
FF Reputation: 1 Pytcokid56 Good Standing Member
Yeah I am a spirited driver. I will check the fluid levels, I was just curious if others have had similar problems. Thanks for the advice guys, its all definitely a help.
Pytcokid56 is offline
Old 01-21-2013, 08:37 PM   #12
Pytcokid56
Pytcokid56's Avatar
Fan#: 87859
Originally Posted by mikebontoft View Post
Thats normal for it to not hit overdrive for awhile if you're flooring it like I think you are.
I get what your sayin here, but Ive had the car for a while and its shifting completely different now that it was even a month ago. Ya know that feeling you have when you just KNOW something is different or wrong with your car? Thats what Im gettin cause it just isnt right.
Old 01-22-2013, 12:39 AM   #13
Focusblackzx5
Focusblackzx5's Avatar
Fan#: 95212
What I Drive: 2012 Mitsubishi Lancer
Points 1,323, Level 20
Points: 1,323, Level: 20 Points: 1,323, Level: 20 Points: 1,323, Level: 20
Level Up 23% Completed
FF Reputation: 1 Focusblackzx5 Good Standing Member
I think its a transmission sensor. On my previous 2003 auto it did the same thing and it was a broken sensor in the transmission. After that everything was working good again. Total cost : 75$
2012 White Mitsubishi Lancer 2.0L : New car
2005 Black Ford Focus zx5 SES : Trade In
2003 Arizonna beige Ford Focus SE : Sold
Focusblackzx5 is offline
Old 01-22-2013, 11:50 AM   #14
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
How does it operate in manual-1st gear?
(SSA is used for 4th gear and man-1st)
If the temp sensor is seeing high temps, the warning light should come on unless it is burned out. But that would put the cart in limp home mode.
elsolo is offline
Old 01-22-2013, 12:56 PM   #15
Pytcokid56
Pytcokid56's Avatar
Fan#: 87859
Im headed out the for to check the fluids. Gettin a diagnostic done sometime this week. Hopefully it is just a quick an easy fix. The manual first works fine. And the temp gauge is showin a perfect temp.
Life is really simple, but we insist on making it complicated.
Confucius
Old 01-23-2013, 08:23 AM   #16
Pytcokid56
Pytcokid56's Avatar
Fan#: 87859
Got the fluid checked, it was low so I added some. It helped a bit but I still think I'm going to take it to the dealer for a flush an a new batch of transmission oil.
Confucius
Old 01-23-2013, 10:19 AM   #17
curtisparker82
Fan#: 108061
What I Drive: 2002 black zx5
FF Reputation: 1 curtisparker82 Good Standing Member
If it's going into neutral about the time it should go into od try turning od off and drive it my 02 had the od solenoid go bad....
curtisparker82 is offline
Old 03-15-2013, 09:08 PM   #18
Pytcokid56
Pytcokid56's Avatar
Fan#: 87859
Ok so Trans update... I have the P0772 code showin and I can't get out of second gear or turn my o/d off.
Confucius
