qweesy's SVT build thread - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-13-2013, 09:34 AM   #71
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,257, Level 35
Points: 3,257, Level: 35 Points: 3,257, Level: 35 Points: 3,257, Level: 35
Level Up 38% Completed
Forum Activity 18%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by SVT Nape View Post
Excellent job good sir!
Thank you
qweesy is offline
Old 12-13-2013, 10:33 AM   #72
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,337, Level 46
Points: 5,337, Level: 46 Points: 5,337, Level: 46 Points: 5,337, Level: 46
Level Up 94% Completed
Forum Activity 19%
FF Reputation: 6 SlickWilly Good Standing Member
Extremely clean.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is online now
Old 03-20-2014, 02:06 PM   #73
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,328, Level 29
Points: 2,328, Level: 29 Points: 2,328, Level: 29 Points: 2,328, Level: 29
Level Up 19% Completed
FF Reputation: 0 smallblockfever Newbie
I know its been said before, but it definitely warrants another round:
Killer job man, super clean build done right- fixing all the little stuff so it doesn't bite you later.
Not gonna lie, my build is going to mimic this almost to a t...
I need all of the repairs you've done, I've just got other pressing issues that require a larger portion of funds
I have a lot of extra wires from the previous owner (an idiot who did his own "maintenance") that need to be removed and there's a lot of wire looms and brackets that are just simply not where they're supposed to be.
I'm hesitant to dive in headfirst on relooming the wiring harness because im worried I won't ever get it back together or I will have to take so much of the engine apart I'll have to drop more money on repairs to put it back together.
What do you suggest on that? Was it time intensive? Should I get a dedicated DD before I tackle it?
"Never miss a good chance to shut up."
smallblockfever is online now
Old 03-20-2014, 03:44 PM   #74
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 18%
my wires were in the right place just all the looms brittle it is a PITA and Ive only done the 2/3's of it I have a lot of updates coming PM me and ill give you my phone number
qweesy is offline
Old 05-08-2014, 05:50 PM   #75
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Hatchback SE RR DCT "Fiona"
Points 6,101, Level 50
Points: 6,101, Level: 50 Points: 6,101, Level: 50 Points: 6,101, Level: 50
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 73%
Activity: 73% Activity: 73% Activity: 73%
FF Reputation: 2 Jburks Good Standing Member
any updates. i know you had mentioned taking the foam out of the rear bumper and putting a air tank in there. what would that be for? Car looks great man!
Green Filters drop in-Snorkel Delete-Steeda RSB-Fswerks RMM insert-Focus Power Tune.
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is online now
Old 05-09-2014, 11:11 AM   #76
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 18%
Some coming this weekend its just been raining every time i go to Bedias so ive been lazy,I have a new baby on the way so I have to get my car and my wifes car done before the end of July.
Ill be taking out the foam from the rear bumper to hide 4 Train horns ;)
Thank you
qweesy is offline
Old 05-12-2014, 01:35 AM   #77
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 18%
So here's little update and should be pretty regular now... I have to get this car done before the baby gets here in July/August
Got rid of the barely charging DB 200amp H/O alternator..... replaced it with the OEM Ford unit ,thought id post a pic for y'all of how it needs to come out (the orientation) without removing motor mounts. it wont come out any other way and it has to go back in the same way,
1.) remove vapor can
2.) unplug vapor line from pipe that runs down firewall
2.) undo plug connectors in that area
4.) Unbolt ground wire and bend that tap down as much as you can
5.) now you can get the alternator out an in
Look at all that room
Before you install the new one make sure these adjuster ears are pushed all the way in otherwise it wont slide on the bracket very easy.
Next I needed to change out the windshield trim since it was all sun-baked and cracked which was allowing water down in the passenger foot well and the pollen filter
Out with the old..
This pollen filter has been in there for about a year and the inside air started to smell a little funky.
They also sell activated charcoal pollen filters now, same price as the regular it will get rid of funky smells I just got the regular since it had more pleats to filter dust and dirt.
Much better now
Here is the usual spot where it will leak notice that even the new one is raised a little bit(not as bad as the old one, but i kept a hose running on it and no leaks so its all good.
Got some new Steeda floor mats they even came with the rear seat mats much better than the factory, Wish I got a set of Redline mats before their embroider went out of business but the Steeda mats are really nice and fill the floor pans front and rear better than the OEM Focus embroidered mats. I haven't put them in the car yet cause i need to do a little cleaning first.
Stay tuned more to come next week
qweesy is offline
Old 05-21-2014, 02:33 AM   #78
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 18%
So A while back i peeled off the gay pinstripe.... well all the residue was left... Goo goner was taking forever,SO I got this 3M Wax/Rubber wheel.... this guy makes a MESS! did the job though without messing up the paint....Not that the 10 year old paint job is worth a shit but now I dont have to look at that residue every time in get in the car.
Before
Clean area well this residue had a bunch of sand in it
After
Next was to install the redline dead pedal
Then the Redline Hood Struts
Oh YEAH!
qweesy is offline
Old 05-21-2014, 06:22 AM   #79
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
FF Reputation: 1 ShadowFocus603 Good Standing Member
Looking good Qweesy. I got a set of those hood struts and that dead pedal in my future as well.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
Old 05-21-2014, 10:28 AM   #80
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,599, Level 58
Points: 7,599, Level: 58 Points: 7,599, Level: 58 Points: 7,599, Level: 58
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Looks good. Think I might have to do the red line strut kit myself.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
