#11 | ||||
'02 Infra-Red SVT; I beat a Camry once. Mods: K&N Filter, FSWERKS Race Exhaust. "It's more fun to drive a slow car fast than a fast car slow.." |
#12 | ||||
quick update got the Eibach bars, installed the 25mm rear bar and got the rear suspension complete next weekend moving on to revamp the front suspension
#13 | ||||
LED ADDICT
nice i want to upgrade my sways..
TeamFOCALIZE!// HATCH NATION #45// October '12 ROTM Track build will commence by Christmas (hopefully) |
#14 | ||||
So this weekend I installed new battery cables cause I kept having the car shut off at random and all sorts of flickering/ gauges going haywire upon inspection of the old wires the were corroded and green ( Ive already done the alternator pigtail,adjusted the Headlight dimmer switch and checked all grounds) will be adding the BIG 3 soon.... WHAT A BITCH to take out and put on new ones and I even had the Cat completely removed.
I pulled out the Front lower control arms so the rubbers can be burned out for the poly to be put in. I also noticed that all of the wiring split loom is just disintegrating so I'm going to refresh that aswell so I don't have wiring harness problems later down the road and the SVT clutch line "going to the bleeder" there is about 6 inches of rubber hydraulic line that the casing looks to be dry rotted but no leaking yet.....I just hope it lasts till the clutch goes out anyone else have this problem? All these old parts will be for sale parts have around 95k on them and all in good working order. So if you want something just PM me when I get caught up ill update the F/S thread,The stock SVT swaybars will have NEW poly bushings (Front 20mm +21mm mounts, Rear 22mm/endlinks Rear) since I got Eibach bars and they already came with poly Out with the old
#15 | ||||
Shrink All The Cars!
I like where this is going! Could we see a pic of your car?
Hatch Nation #8
September 2012 Ride of the Month | Ford of Europe | Hofele | Rieger | Hella | OEM+ | |
#17 | ||||
What he said
Sent from Jeremy's iPhone |
#18 | ||||
car pics added to the first post..
So I was sick hacking up loogies all this weekend but got the Front control arms done all I can say is what a Bi^ch, added the Moog HD ball joints, I did bork one of the rivet holes a little with the drill but not to bad. tightened these down to 60 Ft. Lb. and no movement ill check them after I run them maybe ill drill bigger holes and get fatter bolts to hold the ball joint on the arm if its an issue. I also painted the arms waited 8 hours... put on last coat on and they started to orange peel..... oh well ill sand them down next time i do ball joints and do a better job I should have let them sit for a full 24 hours without jacking with them. I would have had the front struts done as-well but forgot to buy the dust boot HOLDER!... The next 2 to 3 weekends are a big push to get this car back on the road being that I need to return the rental car. Mods will continue in this thread though ![]() ![]()
#19 | ||||
LED ADDICT
how hard was it to press those in?
i'm gonna be getting a 12 ton (or 20 ton) shop press
#20 | ||||
The small ones went in by hand and the center collar with a rubber mallet the big ones went in like butter with the press just lube it real good.....a second set of hands helps, but I did it by myself " I got the 20 Ton from Harbor Freight" they have it on sale right now for $159
| Thread Tools | |
| Display Modes | |
