Oxygen Sensors, OL faults, and crazy volts - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-21-2013, 09:38 PM   #21
SanduskySerpents
Fan#: 78065
What I Drive: 02 Silver Focus SE
FF Reputation: 4 SanduskySerpents Good Standing Member
When I rewired the o2 sensors they started functioning again. In all this mess I think I have solved it. Idle was ruff sounding like an overly aggressive camshaft were in it always about to die. I performed a smoke test after rewireing failed to fix everything and I found a that the EGR gasket failed catastrophically . After this I pressurized the cooling system a found 3 hoses leaking. Replaced gasket and hoses and it started idling 90% better. The unmetered air was causing it to go into open loop fault which just exasperated the problem.
SanduskySerpents is offline
Old 01-21-2013, 09:49 PM   #22
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Well I had that in there somewhere and redid my post since it wandered too much.
Sorry.
Point was, O2 sensor circuits are low voltage, when cut they need best connection possible, I've cut them before, preferable to solder them to prevent later humid conditions messing up the connection by corrosion, it doesn't have to be visible corrosion to cause trouble there.
amc49 is offline
Old 01-21-2013, 09:56 PM   #23
SanduskySerpents
Fan#: 78065
Yeah I didn't solder them but I did use heat shrink over the connectors to weather proof.
Old 01-21-2013, 10:41 PM   #24
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,712, Level 78
Points: 14,712, Level: 78 Points: 14,712, Level: 78 Points: 14,712, Level: 78
Level Up 66% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 90 goinloco1 Excellent Standing Member
The downstream o2 does nothing but monitor the cat. If your getting wierd readings on it and your upstream your cat may be shot. your saying it runs like crap and isn't drivable also leads me this way.
By the way, stay away from bosch sensors, they are either crap right from the factory or burn up shortly. Definitely stay away from the bosch universals where you have to splice wires.
As was said, stick with oem.
goinloco1 is online now
Old 01-21-2013, 10:47 PM   #25
SanduskySerpents
Fan#: 78065
The erratic readings came from th OL fault and bad wiring. But it's fixed now. The car only has what I would call the usual stumble. It's not perfect but it runs
Old 01-21-2013, 10:59 PM   #26
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 21%
my bad, missed that post...lol
got to reading everything else and musta skimmed it.
Old 01-21-2013, 11:02 PM   #27
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 21%
May want to go to the parts store and grab a can of maf cleaner. May take care of some of the other problems or at least smooth them out some. no telling how long its been since its been cleaned last.
