quick question - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2013, 02:18 AM   #11
Duhamel
Duhamel's Avatar
Fan#: 78883
What I Drive: 2009 Silver SES
Points 634, Level 12
Points: 634, Level: 12 Points: 634, Level: 12 Points: 634, Level: 12
Level Up 68% Completed
FF Reputation: 1 Duhamel Good Standing Member
Baldurs,
Did you remove the grille from the full piece with the honeycomb/mesh part? As in, you only had the part with the two bars and logo to tend with? Just asking. All I used was cheap grey primer, 3 coats, and Dupli-color black, 3 coats, and put each coat on while the other was slightly tacky (5-10 minutes), which was after sanding the entire surface with 360 grit and wiping it with a tack/tacky cloth. The only issue is re-attaching the grille. I had to use 3m double-sided "tape". You can easily see the bolt that holds the logo on when you have it separated from the honeycomb/mesh part.
Mine's held up for over 8,000 miles/12,000 kms with barely any chipping, and it was chrome to begin with.
Edit - I also prepped and painted my fog bezels and chrome accent rings with the same process and color, which is holding up even better than the grille. I can't stand the flat black plastic crap.
SRI, Lowered (Pro Kit)
Duhamel is offline
Old 01-22-2013, 01:06 PM   #12
Justinr666
Justinr666's Avatar
Fan#: 96239
What I Drive: 2008 Ice Blue S
FF Reputation: 2 Justinr666 Good Standing Member
Originally Posted by Duhamel View Post
Baldurs,
you do need to separate the grill to do that... i took my logo off
o paint the grill while leaving the honey comb on. so its not necessary to remove it to take the logo off
Justinr666 is offline
Old 01-24-2013, 12:05 PM   #13
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by Baldurs390 View Post
WHOA WHOA WHOA if you are looking for a new grille with black chrome, that's not what you want to buy. That listing doesn't have the chrome (Shiny or Black) on it at all. That item is ONLY the plastic, you still need to add the chrome bars (see pic) and the logo. If you are looking to get a black OEM grille, keep looking.
Source: I bought the same thing on Ebay when I was re-building my car.
Bars by DarderSauce, on Flickr
If you can't wear it out, burn it off
DarderSauce is offline
Old 02-10-2013, 07:25 PM   #14
Thermal
Fan#: 73810
What I Drive: 2008 Pitch Black S
FF Reputation: 1 Thermal Good Standing Member
It's held on with steel "bolts" that cut into the plastic pins. It's easy to remove. Good luck with the grill. I've tried Black Chrome but didn't like the look. Tried 3m carbon fiber overlay but the sun shrunk all the tight corners. I'll try a black paint job when Spring comes.
Thermal is offline
