Windshield wipers won't work correctly - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-19-2013, 06:45 PM   #1
Slowww05
Fan#: 108446
What I Drive: 2005 gray zx3
FF Reputation: 1 Slowww05 Good Standing Member
This is a 2005 focus zx3 the wipers speed adjustment nob won't do anything when I twist it also, rear wiper won't work.....any ideas? Oh the front wipers will still come on in high & the next speed below that
Slowww05 is offline
Old 01-19-2013, 11:51 PM   #2
Dardas
Dardas's Avatar
Fan#: 107673
What I Drive: 2005 Saab 9-3 Turbo 5spd
FF Reputation: 1 Dardas Good Standing Member
my wipers have a minor problem as well, only on the low setting... when they come up and then go back down they dont go down all the way like they are supposed to, they stay a little above on the windshield and if im going on the highway at higher speeds its worse.
i looked this up before and i believe there is some sort of fuse for this, its not in the fuse box its locked underneath the passenger side i believe, im not 100% but i believe it has something to do with that. i just have never bothered to try and fix it.
Dardas is offline
Old 01-20-2013, 01:47 AM   #3
Nevin W
Nevin W's Avatar
Fan#: 98043
What I Drive: 1994 Chevy S10 4x4
Points 1,524, Level 22
Points: 1,524, Level: 22 Points: 1,524, Level: 22 Points: 1,524, Level: 22
Level Up 24% Completed
FF Reputation: 2 Nevin W Good Standing Member
Hey guys, two things could be causing this. First is the wiring inside the boot located between the hatch and car. Second is the relay issue, here is the link to that: http://www.focusfanatics.com/forum/s....php?p=1912363
I suggest you try both of these, I had issues with both my wipers in the front and rear and after fixing both of these it works awesome! : )
PNW Crew #45
1994 Chevy S10 4x4 w/ 4.3 Vortec
2002 Sonic Blue Focus SVT Supercharged - SOLD
2002 Liquid Grey Metallic Wagon - SOLD
Nevin
Nevin W is offline
Old 01-20-2013, 06:39 AM   #4
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,164, Level 46
Points: 5,164, Level: 46 Points: 5,164, Level: 46 Points: 5,164, Level: 46
Level Up 7% Completed
FF Reputation: 68 TerryB Excellent Standing Member
If the relays are still functional, you can easily change the wiper switch. All you have to do is lift the top steering column cover and push in a lock tab. Then just lift it out. It takes about 5 minutes to do.
TerryB is offline
Old 01-20-2013, 03:38 PM   #5
Dardas
Dardas's Avatar
Fan#: 107673
Id like to try this first, do you know of any pictures of this? i dont know how to do this
Dardas is offline
Old 01-20-2013, 04:39 PM   #6
TerryB
TerryB's Avatar
Fan#: 34559
The cover just pops up. The is a tab on each side. Just push those in with a flathead screwdriver and lift. The switch has a tab that you push in and lift at the same time. The new switch will drop right in. You'll hear a click when it's locked.
TerryB is offline
Old 01-20-2013, 05:17 PM   #7
Dardas
Dardas's Avatar
Fan#: 107673
alright very good picture, so im guessing the switch is easy to replace?
Dardas is offline
Old 01-20-2013, 06:03 PM   #8
TerryB
TerryB's Avatar
Fan#: 34559
Yup, should take all of 10 minutes.
TerryB is offline
