ARP main stud to lower crankcase clarence issues... and how i solved it - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-19-2013, 03:43 PM   #1
200two-zx3
200two-zx3's Avatar
Fan#: 108491
What I Drive: 2002 blue zx3
FF Reputation: 2 200two-zx3 Good Standing Member
While rebuilding my 02 zetec engine I replaced my main bolts with ARP main studs which are wayyy stronger, when doing so even with the correct ARP part used you will run into major clarence issues. I'm currently getting my camera fixed so it will connect and so I can make a step by step of how I fixed it also id like for other people to include how they fixed it... this will help anyone who builds the 2.0 engine in the future. Also for those who think you can reuse ur old main and rod bolts you shouldnt as they are a torque to yeild style bolt that should be replaced everytime.
Claim not, dynos prove all!
200two-zx3 is offline
Old 01-19-2013, 05:40 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
You can reuse you main bolts but you need to check and make sure they haven't stretched to much, and a lot of people just use a dremel and cut out the part that hits
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 01-19-2013, 07:15 PM   #3
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Yeah, and where is that spec for max allowable stretch, surprise it doesn't exist. One should realize if bolt has physically deformed to stay permanently longer, it has already partially failed, which is what TTY bolts do the first time they are used. It would be quite dumb to risk an engine on that................
amc49 is offline
Old 01-19-2013, 08:22 PM   #4
200two-zx3
200two-zx3's Avatar
Fan#: 108491
You are 100% correct if you reuse a tty bolt you risk wasting all the time and money you put into the engine...
NEVER REUSE TTY BOLTS Just a side note for everyone
Old 01-25-2013, 02:01 AM   #5
200two-zx3
200two-zx3's Avatar
Fan#: 108491
so I cant just upload pics from my comp. directly to the convo??? do I have to load them on a photobucket site first? I have a complete step by step thing on how I solved this issue but it wint let me post it
Old 01-25-2013, 03:05 AM   #6
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Yes you need to use photobucket or something of the like.
To embed them here use,
[IMG]paste the http here[/IMG]
I look forward to the how to.
You will get a Rep point by doing so.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 01-25-2013, 08:14 AM   #7
pacosarae
Fan#: 109063
What I Drive: 2003 Pitch Black ZX3
FF Reputation: 1 pacosarae Good Standing Member
pacosarae is offline
Old 01-25-2013, 12:06 PM   #8
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
am sure this is what you did to get clearance for the ARP main studs.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 02-02-2013, 12:10 AM   #9
200two-zx3
200two-zx3's Avatar
Fan#: 108491
first you need some good ole ARP studs
next you'll install them via instructions included and using the torque lube
then you'll notice the studs are way longer then the stock bolts
then I decided to trim down the stud after installing the nut and marking the stud and removing them as to not put metal shaving and grindings in the engine while making sure I don't take too much off and hurt the integrity of the stud
this will also reduce the amount aluminum you have to remove from the bottom crankcase assy
above I marked the area where your stud will hit if not notched out also below
next you will need a tool of choice mine is here
and perform your notching I also used a air powered 90 degree cutoff wheel
the angles are messing with how the clearance looks but its evenly cut out around the nut
then ur done with this issue
then you'll be done and happy
Old 02-02-2013, 12:13 AM   #10
200two-zx3
200two-zx3's Avatar
Fan#: 108491
also im missing some pics that wont upload but you get the idea
