POssibly buying, looking for advice. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-18-2013, 03:41 PM   #1
Russo2
Fan#: 108713
What I Drive: 1990 F150
FF Reputation: 1 Russo2 Good Standing Member
Hey guys, I'm new here and don't have a focus yet.
I'm looking at two different ones at a local lot to replace my truck as a cheap dd for school and work. (long commute for school and 10mpg don't mix)
First one is a 2000 focus five speed. 106 thousand miles has a new clutch and blah blah blah, but it's hard to shift first and second gear. Not a normal hard to shift, almost like it's pushing against a gelled up fluid? Is this maybe the cable or the trans itself? Or even just the shifter? Otherwise the car runs great, just a noise rattle box.
Anything else I should know about the 2000 in particular? Any reason to stay away regardless of the low price.
The second is a 2003 five speed. 166k miles. Same rattliness as the 2000, but it shifts better. Runs fine and everything, but has those extra miles and a higher asking price.
Looking for any advice here on either car. Thanks.
Russo2 is offline
Old 01-18-2013, 03:58 PM   #2
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
Hi, and welcome to the Site!
Check the engine on the 2000. If it says SPI on the valve cover, dont touch it! The valves are known to go on the SPI motor at high mileage, as early as roughly 120k miles. If the motor says Zetec on it, it's a keeper! The shifting issue is also relatively common on the focus. Mine does that too. There are a few possible causes. Either the shift linkage isn't properly sealed and has allowed water in, which will freeze the cables (the car will shift better once they've thawed) or it could be bad clutch fluid. But bad shifting from 1st to 2nd isn't too uncommon.
With whatever you decide to buy, good luck! And keep us posted!
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 01-18-2013, 04:05 PM   #3
Russo2
Fan#: 108713
Thanks man, I've been reading into the shifter system of these things and I was thinking the same, figured they will either work loose after being driven (the car has been around awhile not being driven much) and if they don't I considered trying new cables.
I did just read about the SPI motor, I didn't even look at the 2000, but I think the 03 was SPI and at 166k.
I'm not looking at these cars as anything more than a commuter, but a shotty engine is the last thing I need.
Russo2 is offline
Old 01-18-2013, 04:18 PM   #4
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
Exactly. I'm a college student too, I know how fast money flies out of the wallet! Especially if you want neat things like a place to live or food...
Old 01-18-2013, 04:23 PM   #5
Russo2
Fan#: 108713
It's been flying out real fast thanks to my bright idea "this truck needs a lift kit and I should commute to school too!"
Hence the getting a car and I bleed blue, so a focus seemed fitting. I will stop back at the lot soon and see if it's hopefully a zetec motor, if so I'm buying. If not.. I guess I continue on my search.
Thanks again.
Russo2 is offline
Old 01-18-2013, 04:42 PM   #6
Buddy4679
Browser
Buddy4679's Avatar
Fan#: 94214
What I Drive: 2014 PB ST3
Points 1,940, Level 26
Points: 1,940, Level: 26 Points: 1,940, Level: 26 Points: 1,940, Level: 26
Level Up 40% Completed
Forum Activity 3%
FF Reputation: 2 Buddy4679 Good Standing Member
What are they asking for each of these cars?
Originally Posted by Malibooya View Post
I'm pretty much the biggest tool that could ever be in my car.
!!2003 SVT is GONE!!
2007 Silver Chevy TrailBlazer--GONE!!
2014 Performance Blue ST3
#128 Hatch Nation
Buddy4679 is online now
Old 01-18-2013, 04:49 PM   #7
Russo2
Fan#: 108713
1800 for the 2000 and 2600 for the 03. The 03 is a little rich for my blood, it has factory disc and all power etc etc, but it's 166k miles and still ten years old. Your thoughts?
Russo2 is offline
Old 01-18-2013, 05:01 PM   #8
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
Pull of the air box and the engine fuse cable and look at the shift cables. It should look like this.
And not like this
Also the one with a new clutch may have had the trans filled with ATF or the wrong transmission fluid. Putting in the Ford fluid may help it out.
gondorian is offline
Old 01-18-2013, 05:19 PM   #9
Russo2
Fan#: 108713
I will have to stop in again next week when I have more time and check it out further. How do you fill these transmissions? I know every truck five speed I've dealt with is a pain without any sort of real fill tube.
Also is there anything that can be done to quiet down or smooth out these cars without a big price tag or am I dreaming?
Am I playing with a ticking time bomb if it's a SPI and runs good?
And you guys have been a great help already, this forum is one of the better ones I've been on. Just don't tell the truck guys that.
Russo2 is offline
Old 01-18-2013, 06:21 PM   #10
gondorian
gondorian's Avatar
Fan#: 105695
Here is a good how-to for the trans fluid. It does help to buy some tubing from the hardware store but that costs maybe $2. What do you mean make it quieter? Road noise or the vehicle itself operating?
