My car leaks...I hate rain - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-18-2013, 12:34 PM   #1
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,324, Level 29
Points: 2,324, Level: 29 Points: 2,324, Level: 29 Points: 2,324, Level: 29
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 0 smallblockfever Newbie
I drive a 2002 sonic blue SVT
her name is sasha
Sasha is slowly getting repairs and upgrades, but one thing that i failed to fix all last summer was a leak!
I discovered one day after a heavy rain storm that i had about an inch of water in my spare tire well. The jack was rusted through as was the metal in the well.
I pulled off the rear bumper as well as the ENTIRE interior of the car.
I searched and searched for the leak, simulating a monsoon of a rain storm, and tried sealing what i thought was the leak. Afterwards, i sanded and painted all the rusted metal and cleaned the car and everything, put it all back together and thought i was done.
Lo and behold, i used old silicone and it never dried.
Sasha still leaks.
Nothing to rust now, but just knowing that i have water back there bothers me hugely, and i want to upgrade the stereo and make a falsefloor, put some serious investment back there. I cant do that with a wet floor.
I think it is leaking from a bolt hear on the driver rear tail light because it runs down a sidewall inside by the air vent (that is usuallly under the exterior bumper) and leaks through and runs into the spare tire well.
Has anyone had a similar problem with their car? any tips of finding the leak? and sealing it?
any body shop guys that can tell me common places to have leaks??
any help is greatly appreciated.
smallblockfever is online now
Old 01-18-2013, 01:08 PM   #2
Dardas
Dardas's Avatar
Fan#: 107673
What I Drive: 2005 Saab 9-3 Turbo 5spd
FF Reputation: 1 Dardas Good Standing Member
My car had the same problem... one day i opened the trunk up and realized the mat was soaking wet, i took it off and sure enough the whole spare tire compartment was filled with water.. i unplugged the the plastic piece on the bottom and let the water drained out. After examining the car i noticed that a plastic pieces that holds the taillights in place was missing on the right side, went to ford bought the part put it on and it still did it.. all my seals were good.. i ended up replacing my taillight with aftermarket ones and after that i havent had any issues. another problem that i thought of was water coming from underneath from the wheel well. mine are shot, they are starting to break off so i put mudflaps on the back and that might of helped to, but being January now and me living in snowy environments i have not had a problem since i replaced the lights and mudflaps in fall.
Dardas is offline
Old 01-18-2013, 03:53 PM   #3
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,295, Level 98
Points: 28,295, Level: 98 Points: 28,295, Level: 98 Points: 28,295, Level: 98
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
pop the tail lights out and use some good silicone there. both of my foci had that issue. both were hatches and my 2nd i bought new then this leak showed up at 30k. the stock seals suck
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 01-18-2013, 04:17 PM   #4
jakeru
Fan#: 108658
What I Drive: 2001 Street Edition
FF Reputation: 1 jakeru Good Standing Member
I had a water leak in my 2001 Focus wagon, but it would collect in the rear passenger side floor area. Turns out the water was leaking back there from the front. The water was entering into the cabin area from the rear of the front passenger side fender into the floor area, leaking around a grommet for a major wiring loom that wasn't quite sealed well enough to the sheetmetal. The water entering the raintray area would, by design, leak sideways into the fender area, and then trickly its way down past the grommet, and some of that water would enter the passenger compartment area,
I remember removing the passenger fender for access to the loom and grommet. Removal of the grommet was not feasible, so I tried re-seating the grommet better, and sealed it additionally with silicone.
I found the location of the leak by peeling back some of the carpet, and tracing it's way upstream. Spraying water on the windshield would trigger the leak.
I'm not sure if this is your leak of not. It was quite aggravating to find, but I am so happy to have a dry car now that it's fixed. It was horrible, with standing water back there, and fogging all the windows up all the time. Now completely dry. Good luck.
jakeru is offline
Old 07-25-2013, 05:18 PM   #5
smallblockfever
Fan#: 95004
resurrecting this because i realize i never responded with my fix.
Where the side body panel in the rear meets the sheet metal to the floor (behind the subwoofer box and under the bumper) there was not an appropriate weld. I siliconed the bejeezus out of that and then sprayed some flex seal on the inside and VOILA problem solved 100%
Old 07-25-2013, 05:30 PM   #6
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Nice fix.
Sasha is a boy's name FWIW
But, it can be gender neutral in this country.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 07-25-2013, 06:44 PM   #7
smallblockfever
Fan#: 95004
i always saw it as female, but yea unisex works too! haha
Old 07-25-2013, 06:59 PM   #8
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
I have the same problem, but I think mine is due to the lights. I got the car with cheap aftermarket ones and the seals are all dryrotted on them. I might just keep the rubber plug out of the bottom for now...
FoMoCus is offline
Old 07-27-2013, 02:48 PM   #9
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
There are 5000 potential leaks wherever panels join in unibody cars and very common up around the cowl area that takes large amounts of drainage off windshield. The welds are not intended to seal, they use a caulk of varying types depending on location, some is put on melted hot and dries hard. Any cracks later can cause a leak.
After siliconing in a known error place or two and not being happy with the result, I went to using roofing cement like in gallon can from Home Depot. Basically thin cut tar that requires no heat and can be applied with a brush. It dries half resilient yet very firm and will cover dirty surfaces to not leak so much better than silicon it's not even funny. Work the dirt into it and dirt then becomes part of it, silicon requires a really clean smooth surface, you have much trouble getting that in and around cowl panels. Have even used the tar on windshields and no leak ever at any one done like that. Work the area with a small paintbrush to get all contaminants mixed in good and you're done. Messy though. But brother does it work.
amc49 is offline
