Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 01-18-2013, 09:39 AM   #1
CDNFocusFan
Fan#: 99542
What I Drive: 2012 Tuxedo Black Metallic Titanium
FF Reputation: 1 CDNFocusFan Good Standing Member
Block Heater Question
Hi All,
I recently moved up into Northern Ontario. How can you tell if your block heater is working? I plug my car in every night when it's below -15 C. Recently there's been an extreme cold snap and it seems like even plugged in the car is struggling to start. The battery is cranking but the engine seems like it takes forever to finally get going. It does however heat up within 10 minutes or so. Yesterday in -33 I gave up on trying to start it and hitched a ride to work for fear of killing the battery.
I know the block heater won't keep the coolant hot, or even warm, just wondering if anyone else in this type of climate has experience to share. Is my block heater working just for the simple fact that it even starts in this frozen hell?
CDNFocusFan is offline
Fan#: 1
Old 01-18-2013, 09:43 AM   #2
CDNFocusFan
Fan#: 99542
I should add that my experience in this weather is that the DCT shifts weirdly and it feels like being in a car with someone who's learning how to drive stick. In the summer and fall I had no DCT issues other than some weird noises during the break in period. In this weather though the DCT is struggling.
Old 01-18-2013, 11:55 AM   #3
SaToX
Fan#: 94321
What I Drive: 2012 White Titanium Hatch
FF Reputation: 3 SaToX Good Standing Member
The block heater wont heat the coolant up much at all, I was under the same impression that it wasn't working on our last cold snap (I'm in NB). But if your curious just open the hood and at the back side of the motor is where it goes in, you should be able to put your hand on it and feel that it is warm to the touch.
The aluminum block in these cars don't hold heat at all. I have found that they have a hard time keeping warm just idling with the heater on when it starts to get below -15c
SaToX is offline
Old 01-18-2013, 03:52 PM   #4
giles007
Fan#: 107630
What I Drive: 2013 Tangerine Scream ST
FF Reputation: 1 giles007 Good Standing Member
It sounds like your block heater may not be working. My car never cranks that long when plugged in, and it started up right away in -19 weather (sorry baby). It does take 5 to 10 minutes for the coolant to heat up.
If you pop your engine cover off you could see/feel if it is still plugged into the block.
giles007 is offline
Old 01-18-2013, 05:43 PM   #5
Vernl
Fan#: 92066
What I Drive: 2012 Tri white Titanium 401a
FF Reputation: 1 Vernl Good Standing Member
Your engine should be warm to touch when its plugged in and you can hear a slight 'hiss' similar to an electric tea kettle when its plugged in. Also check to make sure that where you are plugging in, actually has power..lots of times an outside plug has a tripped breaker.One more thing in northern climates...switch to a full synthetic oil and use a 0-30 or something similar. It works miracles
Vernl is offline
Old 01-18-2013, 06:18 PM   #6
CDNFocusFan
Fan#: 99542
Thanks for all the replies! I know the outside plug has power since my extension cord has a light in it. I also brought a little light out and tried it on that plug and it works. I'll check the back of the engine in the morning to make sure it's warm.
I just had my last oil change done at the dealership here in town and I'm assuming they used Motorcraft 5w20 but nothing was indicated on the bill. If this cold snap keeps up I'm going to try switching to full-syn.
Old 01-18-2013, 06:20 PM   #7
CDNFocusFan
Fan#: 99542
Really eh? This morning mine cranked for 15-17 seconds and was really not enjoying the cold. There's a loud whistling when it first starts which I think are the active grill shutters. Sounds like a referee's whistle, also 2 high pitched squeaks.
I hate this $*#*%( weather.
Old 01-18-2013, 07:21 PM   #8
giles007
Fan#: 107630
Oh boy, that does not sound pleasant. Full disclosure: I have an ST with a 2.0L but I can't see that making that much of a difference.
giles007 is offline
Old 01-20-2013, 02:12 PM   #9
JMD787
JMD787's Avatar
Fan#: 91481
What I Drive: 2012 Tuxedo Black Ti 5dr
FF Reputation: 1 JMD787 Good Standing Member
How long are you having your car plugged in? It takes about 3 hours for the block heater to get the motor to its hottest point. And it definitely should be reading more towards the middle of your temp gauge. My block heater worked great for 3 months, then quit. Dealer installed a new one and it's been fine ever since. Sounds like you have a bad heater.
Also with those temperatures I would be running a full synthetic oil, 0W20.
JMD787 is offline
Old 01-20-2013, 09:29 PM   #10
ricomtl
ricomtl's Avatar
Fan#: 97818
What I Drive: 2012 Focus Titanium Hatch Tx. Black
FF Reputation: 1 ricomtl Good Standing Member
Montreal here... and we're heading for a ice cold week here... I noticed recently (on very cold mornings), the car struggles in starting even if I leave it plugged it overnight. At first, I assumed it was because I was using a timer and only giving it about 2hrs of warming up before using, so now...even with an overnight charge, it struggles in starting and temp gauge takes quite a while before moving up.
I will pop the hood to see if I feel anything warm... otherwise, off to the dealer.
This is my first car without a starter in over 10yrs and I regret not having one in these friggin cold winter days!
ricomtl is offline
