ATX problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-18-2013, 10:36 AM   #1
Gobliz
Fan#: 101260
What I Drive: 2003 White (for now) ZX5 Non-SVT
FF Reputation: 1 Gobliz Good Standing Member
ATX problems
03 zx5
i get delayed shifting between gears 1 and 2, and 2 and 3.
and today i had a jump between 2 and 3 with slippage and CEL, then another jump got into gear, CEL gone.
Replace solenoids? which ones? or just buy lentech VB?
Cheapest answer is best.
Fluid is black. been meanign to get to that.
-Liz- 2003 ZX5 Zetec 2.0L MPG Mod Euro-conversion (In Progress)
<> KCCO <> Hatch Nation #666 <> Zetec Crew #666 <>
Cars are like women: Treat them right and they give you pleasure; Beat them and they empty your wallet.
Gobliz is offline
Old 01-18-2013, 10:38 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Moved to Technical Chat.
Replace your fluid and filter before going for the solenoids and pray the trans isn't damaged from the lack of maintenance.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 01-18-2013, 10:58 AM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
The black color of your fluid is likely caused by worn hard parts.
Valve body replacement will not correct for worn parts.
If I was to shotgun parts at it hoping for the best, a whole new (used) valve body, fluid and filter. You can find whole, bench tested valve bodies with solenoids for $100 on ebay.
elsolo is offline
Old 01-18-2013, 11:02 AM   #4
Gobliz
Fan#: 101260
well the lentech is the full valve body and solenoids. and of course fluid and filter.
and i've heard nothing but great things about the quality of the lentech shifting.
Gobliz is offline
Old 01-18-2013, 11:10 AM   #5
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
Yes, Lentec makes nice stuff.
Putting their valve body in a trans that has worn out parts is a waste of time and money.
Your trans has issues beyond the valve body.
You may get symptom relief in the short run, but it won't undo damage.
elsolo is offline
Old 01-18-2013, 11:11 AM   #6
Gobliz
Fan#: 101260
oh... what other parts do you think are worn?
Gobliz is offline
Old 01-18-2013, 11:12 AM   #7
Gobliz
Fan#: 101260
and i may be exaggerating with "black" Looks more like...
(Stolen from http://www.focusfanatics.com/forum/showt...ghlight=How-to)
Gobliz is offline
Old 01-18-2013, 01:46 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
clutch friction material
the rubber from all the bonded pistons in these
fine metal dust suspended in the fluid from worn hard parts.
If you let it slip shift too long, the clutch packs will have worn/overheated, no way to fix that except a full rebuild. Same thing for the bonded rubber on the pistons, if the fluid got too hot and any of the rubber failed, full rebuild.
If it were mine, I would just do a full valvebody replacement and see if that fixes the symptoms. I would also start looking around for a Focus being parted out on my area because equal chances I would need a $300-400 take-out transmission.
elsolo is offline
Old 01-18-2013, 01:55 PM   #9
Gobliz
Fan#: 101260
see i was thinking VB, and then if it didn't fix take the VB out and use it in another tranny or sell.
Gobliz is offline
Old 01-18-2013, 02:49 PM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
If it was me, besides changing the fluid and filter way before it got to be the way it is now, I'd change the fluid and filter and see how it was. Swapping the solenoids out may not fix the slipping if the clutch packs are worn out. It's probably been slipping for a while it's just now getting to be very noticeable.
Moderator for
Technical Chat
