finally starting my journey to 450whp - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-23-2013, 08:32 PM   #151
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Originally Posted by turbosvtfocus04 View Post
If the shop doesn't know how to use a dyno then they shouldn't have one.
But tuning on a dynojet vs mustang dyno is night and day difference. But that's my experience.
you would be suprised man.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 01-23-2013, 08:47 PM   #152
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
[QUOTE=Roushturboedzx3;4553763]you would be suprised man.[/
We will see what my 6766 lays down on this mustang dyno. 445whp ran 10.90-11.1's on a 3klbs fwd car.
turbosvtfocus04 is offline
Old 01-23-2013, 08:48 PM   #153
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,973, Level 91
Points: 20,973, Level: 91 Points: 20,973, Level: 91 Points: 20,973, Level: 91
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 11%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
on your car if you truly want to go to 600hp you will need to run a 44/46. a 38/39 will do 450 just fine. but even if you are spraying not boosting up to 600whp then you are still moving more air. the purpose of the larger wg is to allow more ex to pass the turbo. if your running boost and spray with out enough wg then your boost will start to raise no matter what boost is set to when you spray it. if your running a turbo big enough to make 450whp then you dont have to worry about a 44/46 being to big.
as far as the surge tank goes. i dont see you needing to run a larger pump in the stock tank. you can just set it to a full on relay instead of variable. with running a full return set up your still having to run lines and put fittings in so that isnt raising the price any. i think the cost would be close to the same on the two set ups but the surge tank will just allow stock fuel gauge and gets rid of the problems associated with using stock tank for return and would be safer than putting a cell in the passenger compartment.
Tim
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 01-23-2013, 09:49 PM   #154
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,948, Level 79
Points: 14,948, Level: 79 Points: 14,948, Level: 79 Points: 14,948, Level: 79
Level Up 20% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
Ok thanks guys! Keep the info coming! This is a tremendous help! What is your opinion on what size bearings I should run? I cancelled mt order when I saw how widely they varied. Oem 25mm 50mm and 75mm on rod and main bearings
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is online now
Old 01-23-2013, 09:59 PM   #155
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
As long as your crank and rod journals are in good shape standard size will work. Now if you had to send the crank out to get the journals fixed from being scored or scratched then you would order under sized(aka 25mm)
Old 01-23-2013, 10:14 PM   #156
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
So if I have never had a spun bearing, and currently have no bearing noise that would suggest a spun bearing I should be ok with oem? Or should I wait to place the order until after the engine is torn down to see what I need for sure? I can place an order and they should arrive in a week or so unless autozone has what I need
Old 01-23-2013, 10:19 PM   #157
Roushturboedzx3
I Fab Too Much
Fan#: 42814
the correct way would be to tear down the engine and mic the crank and caps to figure out what size bearings you need.
Old 01-23-2013, 10:21 PM   #158
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 11%
go ahead and order std. since you are running the engine now and know it is in good shape there should be no problem with std size. if i find any problem i will let you know and we can decide then to either get a new crank or resurface and over size bearings. probably end up with me at pull a part getting a good one if there is a problem with yours.
Tim
Turbo Turtle Garage
Old 01-23-2013, 10:31 PM   #159
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
right with jim I was going to order race bearings back during my build but my crank and caps were really good condition still so there was no need. and you would need to mic the crank anyawys so std is your easiest and best bet. and real cheap
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 01-23-2013, 10:49 PM   #160
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
Awesome, ty guys. Ill get the order back in. found a 5 gal fuel cell for $25. Should I snag it?
