What the hell... 2005 focus zxw - Page 2 - Focus Fanatics
Old 01-18-2013, 07:54 PM   #11
dieselkiller
Fan#: 93128
What I Drive: 2005 zxw white
FF Reputation: 1 dieselkiller Good Standing Member
will do! where about would the ground connect? im sure someone here has had to dig it out before. also, couldnt i just clip the ground at the harness behind the bulb and eliminate the digging? dont recall seeing a green/yellow ground though.
dieselkiller is offline
Old 01-18-2013, 08:05 PM   #12
elsolo
elsolo's Avatar
Fan#: 96835
Black wire
Green and yellow on a late model car is for the airbag
I would probe the lightbulb socket rather than dig around
elsolo is offline
Old 01-18-2013, 08:07 PM   #13
dieselkiller
Fan#: 93128
will do, ill just throw a tap on it. being lazy tonight.... onward tomorrow.
Old 01-18-2013, 08:11 PM   #14
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 67 sailor Excellent Standing Member
2nd vote for the bad ground, it was my first thought while reading through 'till I saw elsolo already mentioned it!
sailor is offline
Old 01-20-2013, 12:09 AM   #15
dieselkiller
Fan#: 93128
grounded the wire, worked. now my question is since im showing it going to ground with my meter that tells me it may be hanging on by 2 strands. where do those grounds come together? im sure someone has torn down the interior for sound spray or something.
Old 01-20-2013, 02:37 AM   #16
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
those lights probably share a common ground and are being activated as part of the circuit through another ground. Check for a broken ground.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 01-20-2013, 03:01 AM   #17
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: 13 stang
FF Reputation: 90 goinloco1 Excellent Standing Member
the ground is located right below the latch pin under the the plastic trim, at least in sedans and hatches.
go to post 14 , pic 3, in this thread. also notice the main wiring harness connectors are located on the drivers side in the rear corner. (there are also some pics not showing, but the links can be clicked)
http://www.focusfanatics.com/forum/showthread.php?t=122977
Take pics of what your doing, do a write up, and post them up.
goinloco1 is offline
Old 01-20-2013, 08:51 AM   #18
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
This might be a good time to investigate/repair the license plate lights. Those can cause some problems with the other lights, and are typically corroded due to water getting in the hatch trim.
There should be a harness grounding point on the driver's side. The harness comes down the driver's side, then goes up and over to the passenger side. IDK if grounding is repeated on the passenger side.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-20-2013, 12:05 PM   #19
dieselkiller
Fan#: 93128
great tips people! will dig into it in the coming days. 49ers on today, not doing jack. at least its temp grounded so the "man" will pass my us wagoon.
Old 01-20-2013, 12:15 PM   #20
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
Check your hatch wiring again
Read this for more info:
http://www.focusfanatics.com/forum/showthread.php?t=178941
There is a beautiful picture of the wire damage inside the umbilical
I had a 2004 Focus wagon and the rear lights bases would burn out. Found out there are two different bulbs that will fit in there, yet the current draw is larger on one hence the heat. I was going to install the bulb with the light current, but would give less light, but the wagon got totaled by a DWI while parked
mikeeshaq is offline
