What the hell... 2005 focus zxw - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 09:08 PM   #1
dieselkiller
Fan#: 93128
What I Drive: 2005 zxw white
Points 299, Level 5
Points: 299, Level: 5 Points: 299, Level: 5 Points: 299, Level: 5
Level Up 98% Completed
FF Reputation: 1 dieselkiller Good Standing Member
Ok so ive figured for a while that i needed a right rear brake bulb since i was getting the quick blinker. Now that i got off by butt to replace it i noticed that when the brakes are on the reverse lights on both sides come on and the left brake light is bright but the right dims. the only other bulb i have out is the left front side marker. could that lone bulb on the LEFT cause issues on the right? if not..... what the hell?
dieselkiller is offline
Old 01-17-2013, 09:16 PM   #2
dieselkiller
Fan#: 93128
Points 299, Level 5
oh and when the blinker is on the right the dim brake bulb and reverse bulb alternate blinking along with the left reverse light..... ya, what the hell. reverse lights DO come on when in reverse. I live in TX and they do inspections so I have to get this fixed by end of Feb.
Old 01-17-2013, 09:32 PM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,573, Level 53
Points: 6,573, Level: 53 Points: 6,573, Level: 53 Points: 6,573, Level: 53
Level Up 12% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (23)
Check the wiring on the inside where it passes through the hatch(tailgate).
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 01-17-2013, 09:54 PM   #4
dieselkiller
Fan#: 93128
Points 299, Level 5
wow, i figured if it was that it would be blowing a fuse like in my cherokee. i will check it out. any other suggestions if its not that? also, side note; the bulb section is wrong for the 05-07 hatch, 4057 is the correct bulb for the brakes, it shows 3157.
Old 01-18-2013, 09:43 AM   #5
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,727, Level 58
Points: 7,727, Level: 58 Points: 7,727, Level: 58 Points: 7,727, Level: 58
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 24%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Pretty sure those are both almost identical bulbs, both should be dual filament, same size/output. Google 4057 and 3157, they seem to be pretty much the go to brake light bulb for mustangs and f150s and they use them interchangeably too.
I always make it a habit of replacing lights in pairs, especially since they are usually sold that way. Figure if one goes out, the other should be headed that way too. Also, dont have to deal with one being brighter than the other (although shouldnt be an issue with brake lights)
I'd check the wiring, just to make sure no bare wires are exposed or the shielding isnt cracked on them.
rambleon84 is offline
Old 01-18-2013, 12:02 PM   #6
dieselkiller
Fan#: 93128
Points 299, Level 5
Just checked the wiring in the boot at the hatch, it's clean. Nothing even dirty. What would be the next item to check?
Old 01-18-2013, 12:14 PM   #7
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 24%
Were you getting the quick blinker with both turn signals then? You had a right rear brake light out and then front left side marker?
Did you replace that left front side blinker? Has the quick/hyper blinking stopped?
Old 01-18-2013, 12:28 PM   #8
dieselkiller
Fan#: 93128
Points 299, Level 5
No, quick blink with right only. That's why I'm almost dismissing the left side marker as a cause. Symptoms again: quick blink on right with turn and reverse alternating blinks(reverse on on left side while right signal on), and reverse lights on dim when braking with very dim right brake light. Can't imagine a left marker would cause all this. Have not climbed underneath to change market yet.
Old 01-18-2013, 07:14 PM   #9
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
moving this to technical area
fhh02a is offline
Old 01-18-2013, 08:07 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
Thinking out out loud here, may be way off base:
If the ground wire attachment for the tail lamps (on one side) has detached from the chassis, the brake light circuit may be finding ground through the light bulb(s) and circuit for the other lamps at that corner.
All the bulbs at one corner share a ground point.
If that ground is not connected, the circuit would go through the other bulbs and dimly light them up simultaneously as they complete the ground side of the circuit.
So I would check the ground side of the right tail light.
elsolo is offline
