there a way I can take my t/b apart even if it's fbw - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 07:12 PM   #1
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,182, Level 87
Points: 19,182, Level: 87 Points: 19,182, Level: 87 Points: 19,182, Level: 87
Level Up 67% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
I've had just about enough of my little idle problem I've tried cleaning it but it just comes back it's whenever I come to a stop it drops then comes back up, I know that the IACM is a non replaceable part on these t/b's due to the fact that they are fbw or something along those lines. Has anyone taken one of these apart and successfully cleaned one?
badazz2010focus is offline
Old 01-18-2013, 04:59 PM   #2
Snigle
Fan#: 65662
What I Drive: 2007 Silver SE
Points 130, Level 2
Points: 130, Level: 2 Points: 130, Level: 2 Points: 130, Level: 2
Level Up 60% Completed
FF Reputation: 1 Snigle Good Standing Member
I just cleaned mine the other week. It was actually super easy and fixed my sticking accelerator peddle.
1) Disconnect intake hose between air resonator and throttle body. This can be done by loosening the two clams with a flat head screwdriver. It will take some wiggling but it will pop off of the resenator and throttle body.
2) Disconnect sensor cable from throttle body
3) Disconnect the accelerator cable & cruse cable from throttle body
4) Unscrew plastic cover near throttle body
5) Unscrew the 4 bolts that connect the throttle body to the engine.
It should pull right off. On my focus it was made of plastic, so be careful what type of clearer you use. I used this: http://www.amazon.com/CRC-05078-Thro...dp/B000M8PYO2/
My focus is an 07, but I'm sure the 10 is similar.
Snigle is offline
Old 01-18-2013, 06:46 PM   #3
badazz2010focus
Fan#: 78166
Forum Activity 7%
No on the 10s the iac tps etc are all part of the same unit
