Ford's letter regarding the "PowerShift 6 Speed Operating Characteristics" - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 06:55 PM   #1
fomenter
Fan#: 107937
What I Drive: 2013 Ford Focus SE SFE
FF Reputation: 1 fomenter Good Standing Member
After I scheduled my appointment with a ford dealer in TX, ford customer service sent this electronic letter to me...Sooo my understanding is that this car is built to make all kinds of weird noises.
Background
In 2010, Ford launched an all new transmission, PowerShift, an advanced six-speed automatic transmission based on manual transmission technology with class-leading fuel efficiency. This communication will help explain the technology and common operating characteristics of this new transmission found on the Fiesta and Focus in order to improve customer expectations and
experiences. PowerShift is an advanced automatic transmission technology
The PowerShift is really like two 3-speed manual transmissions put together, with the dual clutch and shifting components controlled electronically. Since most of the components are derived from a manual transmission, the PowerShift transmission will drive, sound, and feel like a manual transmission but without the driver interaction.
Service Personnel Support
Since PowerShift Transmission is a new technology, some customers might not be familiar with the normal driving characteristics of this transmission. Service support personnel should be aware of the normal operating characteristics and be able to differentiate between normal characteristics and abnormal symptoms that require service. The following information will
assist with addressing certain potential customer concerns.
Common Characteristics of the PowerShift Transmission
Common Sounds a driver may notice are:
• Double clicking metal sounds. These noises can likely be heard while driving on very smooth surfaces during a 1-2 upshift or a 3-2-1coast down. The sounds occur with every gear engagement, but generally cannot be heard over the background engine, road and wind noises at higher speeds. Most noticeable if the windows are down and the radio is off, these sounds are of the shift forks moving and the synchronizers engaging a gear (similar to a manual transmission). These shifting sounds are part of normal operation.
• Coast down whine. A slight gear whine while slowing or coasting is normal
• Clicking sounds after the engine is turned off. As the vehicle is powered down, the
transmission will cycle the clutches to the released position so it is ready for a safe restart of the engine. This is part of normal operation. Clicking sounds from the
transmission immediately after the engine is turned off are normal.
• Low speed grinding. A slight grinding noise may be heard at about 2 MPH. This noise
is more evident during “trailer-hitching” events (see below). This noise is caused by a
normal bearing rotation and does not affect the durability of the transmission.
• Reverse gear whine. Some PowerShift transmissions will exhibit gear whine in reverse. The level of whine has been significantly reduced in later build vehicles, but can still be detected to some level. This is characteristic of many manual transmissions, and is not a defect or a situation in which a repair should be attempted
Trailer-hitching feel.
Some customers may experience a trailer-hitching feel (or a slight
bumping feel). The trailer-hitching feel may occur in lower forward gears – particularly if the customer is off and on the throttle quickly. It may be more noticeably in a parking lot or when a customer is doing multiple on/off throttle pedal maneuvers. This trailer-hitching/engagement feel is a normal characteristic of the dry clutch-equipped manual transmission design.
Conversely, conventional automatic transmissions are equipped with a torque converter. The torque converter is a fluid coupling device which dampens these positive engagements feels. Diagnostic tips to be used during service visit When evaluating a customer experience regarding this transmission, first compare to a like vehicle. The like vehicle should be at the same transmission fluid temperature as the customer’s vehicle. Sounds will change as the transmission oil changes temperature and viscosity. If the suspect sound is similar to a like transmission at the same temperature, then it is most likely a normal characteristic and no repair attempt should be made.
If the vehicle loses electrical power due to the removal of a power or ground battery cable, or the battery discharges, the transmission will perform an initial system status check upon power restore to verify shift motor position. This results in a series of mechanical noises for 10-30 seconds. The transmission will not engage and the vehicle will not move while this is
happening. This is normal after an electrical power loss to the transmission.
“Green” clutch break-in period
New, replacement, and reset clutches are “green” and require a break in period before shift event quality is maximized. During the break-in period, green clutches may exhibit:
• A rattle noise similar to a loose catalytic converter shield. This noise is commonly heard after light throttle 1-2, 2-3 or 3-4 upshifts. This rattle noise will diminish greatly as the clutch completes the break-in.
• A take-off shudder/launch judder (shaky vs. smooth).
• A harsh-shift feel during the first few cold shifts before the transmission reaches operating temperature.
All of the above conditions will diminish and the customer will notice progressively better launch and smoother shifting within the first few hundred miles of mixed driving as clutch break-in occurs. Note: The break-in process may take longer for highway driving, where the clutch is not shifting.
The transmission will automatically learn and make adaptations during shifting events, so it is important to evaluate after allowing sufficient driving time for adaptations to occur. This green clutch feel may reappear if the clutch touch points are reset and/or the clutch is removed and/or replaced. The condition may last longer for a clutch replacement than a reset. A reset may take up to 100 miles to get the new touch points learned to the point of not making
any of the out-of-adjustment noise. A clutch replacement may take up to 1000 miles to reach break-in dependent on the customer style of driving.
The break-in period can be minimized by performing the adaptive drive cycle exactly as described in the Workshop Manual, Section 307-11 (Fiesta) and 307-01 (Focus)
fomenter is offline
Old 01-17-2013, 07:03 PM   #2
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
This is what I experience the most. It is somewhat annoying but no big deal really. I am glad this is the biggest problem I have with this DCT.
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards
Some Guy From NY is offline
Old 01-17-2013, 07:34 PM   #3
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
I know that some of the noises & behaviors are normal, but the terrible grinding noises some folks are experiencing are beyond the scope of 'reasonable'. Mine never did it at 2900 miles, so why are theirs doing it after 10,000 - 15,000 miles? Yes, I've heard all the little clickety-clack noises while the transmission does its thing driving slowly around parking lots, but the noise that folks have posted on YouTube isn't anything like that. Excuses, excuses. I'm so glad I got out of that car before any issues arose (other than the issues I had with MFT).
cbdallas is offline
Old 01-17-2013, 07:48 PM   #4
Scott02
Fan#: 108080
What I Drive: 2012 Ox White SEL DCT 5dr
FF Reputation: 1 Scott02 Good Standing Member
Everyone who has a DCT trans and think they have, or do not have, issues with it... I strongly suggest to go test drive an automatic Volkswagen car with the DSG Transmission. This way you'll have another dual clutch auto transmission to compare your DCT to.
Scott02 is offline
Old 01-17-2013, 07:56 PM   #5
cbdallas
cbdallas's Avatar
Fan#: 100296
http://www.youtube.com/watch?v=xZ_VGo7ws6k
http://www.youtube.com/watch?v=M3OozxnZxzU
http://www.youtube.com/watch?v=54_3_qF2xhQ
If the VWs make this much noise, they've got problems as well.
cbdallas is offline
Old 01-17-2013, 08:59 PM   #6
cobie56
Fan#: 84403
I drove a dsg equipped golf in iceland for 3 weeks in all kinds of weather and on all types of road/driving conditions and i can tell u without hesitation the vw dsg operated vastly more smoothly and more quietly than my focus' dct
cobie56 is offline
Old 01-17-2013, 09:15 PM   #7
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,336, Level 64
Points: 9,336, Level: 64 Points: 9,336, Level: 64 Points: 9,336, Level: 64
Level Up 96% Completed
FF Reputation: 7 Red Jay 918 Good Standing Member
i still say this all could have been avoided if they just used the Fusion 6 speed auto. i don't know if the DCT was already being sold in Europe, but if not then couldn't they have saved some money just by sourcing the Fusion transmission?
Red Jay 918 is offline
Old 01-17-2013, 09:26 PM   #8
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,057, Level 67
Points: 10,057, Level: 67 Points: 10,057, Level: 67 Points: 10,057, Level: 67
Level Up 2% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
The 6F35 is less efficient, having a fluid coupling (torque converter) and lots of hydraulics. The dry dual clutch Powershift DCT is lighter, simpler, and more efficient when it is functioning properly having been based on a pair of three speed manual transmissions sharing a single transmission case and actuated using servo motors for the gear selection and the clutch actuation.
Personally as long as the DCT works correctly I prefer it over even over a properly working 6F35.
I don't like how the 6F35 operates. The constant locking and unlocking of the torque converter while trying to maintain speed on the freeway, and the fact that it won't shift to 6th before 41 mph in every 2.5 or 3.0L Fusion I'd driven.
It was merely adequate with the 1.6 L ecoBoost in the Escape, but I am not sold on its long term longevity even more so than the DCT. Ford has never really built a great fwd torque converter backed planetary automatic transmission, certainly none of the products to come from the Van Dyke Assembly plant have held up that well. Although in some cases that's due to the prior owners not maintaining them at intervals much more frequently than recommended by the owners guide or the service manual. The AX4N/4F50N tended to implode some point just past 100,000 miles without fail.
suss6052 is offline
Old 01-17-2013, 09:38 PM   #9
felixdd
felixdd's Avatar
Fan#: 105655
What I Drive: 2013 Oxford White SE sports
Points 281, Level 5
Points: 281, Level: 5 Points: 281, Level: 5 Points: 281, Level: 5
Level Up 62% Completed
FF Reputation: 1 felixdd Good Standing Member
My wife has a DSG Golf
No noises. No issues. However, the Golf DOES learn your driving habits. Case in point -- when my wife drives, the car shifts very smoothly. But because of our different habits with the gas pedal, when I am in stop-go traffic, often we get jerky acceleration as I'm on/off the pedals a lot, as if the car is dropping the clutch rather hard. It also has a dull THUD when that occurs. Sort of what the Ford document describes actually.
In general though, the Golf DSG shifts a LOT smoother than the 2012 Focus that I drove for a week as a rental. It performs better in idle-speed, stop/go traffic too.
That's why I bought a manual, although it still clicks when I upshift 1-2 and 2-3, unless I rev-match EXACTLY. Which is sort of annoying considering I never had to do that with other cars.
felixdd is offline
Old 01-17-2013, 09:42 PM   #10
Red Jay 918
Fan#: 79277
was kinda thinking more of the 2013+ Fusions but then again i do mean Fusion in general.... assuming the 2.5L transmission would bolt up to the current direct injected D20. or does the 2013+ use the same transmission as the 10-12?
