2.3 stock cam specs anyone? In Factory Manual? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 06:39 PM   #1
bones33
Fan#: 105414
What I Drive: '05 Silver ST
Points 378, Level 7
Points: 378, Level: 7 Points: 378, Level: 7 Points: 378, Level: 7
Level Up 56% Completed
FF Reputation: 1 bones33 Good Standing Member
Specifically, does anyone have timing and duration events for the stock cam. Lift as well.
Would like it for an approximate comparison to performance cams.
Thanks!
bones33 is offline
Old 02-20-2013, 05:25 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,036, Level 74
Points: 13,036, Level: 74 Points: 13,036, Level: 74 Points: 13,036, Level: 74
Level Up 47% Completed
Forum Activity 99%
Thanks!
Duration @ .050 int. 203/ exh. 190 LS is 110 degrees gross lift= int. .359/ exh. .318 Pretty wimpy. A little more duration & lift gets you a lot. The stock head out flows the oem cams.
felixthecat is online now
Old 02-21-2013, 11:53 AM   #3
bones33
Fan#: 105414
Points 378, Level 7
Thanks Felix. I see what you mean, pretty mild.
Hey, would you happen to know when the intake begins to open BTDC, or closes ABDC?
bones33 is offline
Old 02-21-2013, 01:01 PM   #4
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
No sorry, it doesn't even list it in the shop manual either. To give you a idea, the crane cams I have are= Int. opens -4 degrees atdc/ closes 36 degrees bbdc. Exh= opens 32 degrees bbdc & closes -8 degrees btdc. 4 degrees overlap= intake closes & exhaust opens. This is cranes #224-0010. I do like the next one= 224-0012. Int.= 226 @ .050/exh. 216 @ .050 w/ .410/.385 of lift. Int opens at 3 degrees atdc/ closes at 43 degrees bbdc. exh. opens at 38 degrees bbdc & closes at -2 degrees btdc. The cranes are on a 110 LS vs crowers which are on a 114 LS angle. All the 23 motors should of had cams similar to the cranes spec's to begin w/.
Old 02-25-2013, 12:23 PM   #5
bones33
Fan#: 105414
Points 378, Level 7
Thanks again Felix, I think i can derive some useful data from what you have there.
bones33 is offline
