In the middle of install, speaker wire help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 03:25 PM   #1
BumpandThump
Fan#: 108350
What I Drive: 2013,gray/charcoal black, S manual
FF Reputation: 1 BumpandThump Good Standing Member
Hey, Im in the procces of installing an loc on my 2013 ford focus base. My issue is im not sure if I can follow the wire colors from this site for the earlier models. Everybody says that
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
I see the brown white and brown blue cable (wrapped together) but the other wires are not accurate to whats online. I dont want to assume the wires are the same and have to go back in an undo what I did or damage something by reversing polarity. Please help its getting dark out!
BumpandThump is offline
Old 01-18-2013, 06:10 AM   #2
Flounder
Fan#: 108278
What I Drive: 2013 ruby red SE
FF Reputation: 1 Flounder Good Standing Member
Get a nine volt battery. Put positive wire to positive neg to neg and the speaker they are attached to will make noise.
Flounder is offline
Old 01-18-2013, 08:12 AM   #3
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
no do not use a battery! you only use batteries to test phase. if you hook it on the wrong wires you can cause serious damage or injury.
Here's the info I have for a 2012. should be the same for 13, but there is a chance its not.
Battery BROWN/RED (+) RADIO, PIN 1 OF 24 PIN PLUG
Accessory DATA
Ground BLACK (-) RADIO, PIN 13 OF 24 PIN PLUG
Illumination BROWN (WITHOUT SYNC) (+) RADIO CONTROLS, PIN 3 OF 8 PIN PLUG
Power Antenna YELLOW/ORANGE (+) RADIO, PIN 2 OF 24 PIN PLUG
Amp Turn On YELLOW/PURPLE (+) RADIO, PIN 18 OF 26 PIN BLACK PLUG
LF Speaker (+) WHITE
LF Speaker (-) WHITE/BROWN
RF Speaker (+) WHITE/PURPLE
RF Speaker (-) WHITE/ORANGE
LR Speaker (+) WHITE/GREEN OR BROWN/GREEN
LR Speaker (-) BROWN/YELLOW
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BROWN/BLUE
Amp Location RIGHT SIDE OF CARGO COMPARTMENT
edit: btw, you're not gonna damage anything by having the polarity reversed (out of phase), it just won't sound quite right. you will also need to hook it to the left speaker as well to make sure you are getting all the sound just in case something only plays bass from one side and not both.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
