Header Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 09:18 AM   #1
SPRAYPAINT
SPRAYPAINT's Avatar
Fan#: 89747
What I Drive: 2014 Sterling Grey Focus SE Sedan
Points 2,178, Level 28
Points: 2,178, Level: 28 Points: 2,178, Level: 28 Points: 2,178, Level: 28
Level Up 19% Completed
FF Reputation: 2 SPRAYPAINT Good Standing Member
Header Install
This post is for informational use. If you plan to install a header here are some things I have ran across and may help when getting all the parts together before your install. I have the OBX Maximizer (1 7/8" runners and 2.5" collector) header installed on my 2012 sedan. Originally I had the upstream air fuel ratio sensor installed about 3" away from the head on only #4 cylinder and the downstream was in the collector. After about 100 miles the CEL came on with P0420 cat code and the engine is running VERY rich. After doing research and talking to my techs that work for me the upstream needs to read all 4 cylinders. I started looking for o2 extenders and could not find one for our cars. I found out that our upstream sensors are a 5 wire wide band air fuel ratio sensor and the wires CANNOT be extended doe to too much resistance. After looking around and being on the phone with my vendors I have found that there is a sensor that will work. It is used on the 2007 Porsche Boxter with the 2.7l. Bosch part #17276, Denso part #234-5108, Walker part #250-25015. These sensors are 850mm (about 33.4") and will reach down to the collector with ease. Now for the downstream sensor. It CAN be extended because it is only used to read the cat efficiency. You will need to use a spacer that comes out in a 90 degree for space and to trick the computer. the rear o2 sensor needs to be at least 2.5" or more behind the upstream sensor. I hope this helps.
It is what it is in life... Just have fun with it!
January 2012 Ride Of The Month
SPRAYPAINT is offline
Old 01-17-2013, 09:39 AM   #2
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,231, Level 35
Points: 3,231, Level: 35 Points: 3,231, Level: 35 Points: 3,231, Level: 35
Level Up 21% Completed
FF Reputation: 2 Slo86GT Good Standing Member
Any idea if we'd have luck with an MIL eliminator on the downstream?
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 01-17-2013, 09:58 AM   #3
SPRAYPAINT
SPRAYPAINT's Avatar
Fan#: 89747
I have not looked into it. I'm not a fan of using electrical components. I'm really waiting for a tune. I have no doubt that our cars can put 200HP to the ground with a tuner.
Old 01-17-2013, 10:08 AM   #4
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
I went through a similar process with my FSwerks header. I had an 02 sensor bung welded on at the collector angled at 45 degrees. Been flawless so far!
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 01-17-2013, 06:48 PM   #5
turbo2300
Fan#: 98088
What I Drive: 2012 Sonic Blue Sedan
FF Reputation: 1 turbo2300 Good Standing Member
How do you guys like your headers, sound and performance?
turbo2300 is offline
Old 01-17-2013, 08:16 PM   #6
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,652, Level 97
Points: 26,652, Level: 97 Points: 26,652, Level: 97 Points: 26,652, Level: 97
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 9 TORQUERULES Good Standing Member
What did you do about the sensor wire length in your application?
TORQUERULES is offline
Old 01-19-2013, 02:25 PM   #7
SPRAYPAINT
SPRAYPAINT's Avatar
Fan#: 89747
Old 01-21-2013, 07:39 PM   #8
TORQUERULES
The Professor
Fan#: 1083
Done. Ordered.
Old 01-21-2013, 08:03 PM   #9
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
The header may sound a bit ricey until you get a full blown exhaust system on there, but I don't mind it. I think it sounds pretty good from inside the car lol.
And as far as cable length, it comes with an extension cable from FSwerks, IIRC. If you're doing the install yourself, MAKE SURE TO ZIP TIE IT AWAY FROM HOT SURFACES!!!! When i had the mechanic install mine, They left it resting on the header. When I hooked up my ECU tuner, I couldn't figure out why I couldn't get a reading off of it... It had melted the wire nearly in half, and that extension cable is like 75 friggin bucks from FSwerks.
Old 01-21-2013, 08:21 PM   #10
theshrewz
Fan#: 103228
What I Drive: 2012 Silver Se Focus
Points 2,185, Level 28
Points: 2,185, Level: 28 Points: 2,185, Level: 28 Points: 2,185, Level: 28
Level Up 24% Completed
FF Reputation: 2 theshrewz Good Standing Member
Did my F2 install and Had no issues or CEL light so far, they just plugged one of the O2 ports.
Untitled by theshrewz, on Flickr
theshrewz is offline
