no heat ...any help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-16-2013, 07:17 PM   #1
Wiplash2000V6
Fan#: 27480
What I Drive: silver ST
FF Reputation: 1 Wiplash2000V6 Good Standing Member
no heat ...any help
05 ST ..has no heat. hasnt over heated so most likely not the t-stat or water pump.any ideas what it could be?
Wiplash2000V6 is offline
Old 01-16-2013, 08:16 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Tstat stuck open
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 01-16-2013, 11:52 PM   #3
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
X2, stat sticking open has nothing to do with overheating..............but will kill heat like nobody's business.
amc49 is offline
Old 01-16-2013, 11:56 PM   #4
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
What I Drive: A magical pony by the name of Sally
Points 11,179, Level 69
Points: 11,179, Level: 69 Points: 11,179, Level: 69 Points: 11,179, Level: 69
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 3%
FF Reputation: 9 LouBomb Good Standing Member
Do you have coolant? Lol I kno.. But it's happened to me..
2000 Turbo Zx3
2003 Pitch Black SVT
2000 SPI 220k miles all original THE UNICORN
Focus Revolution Club
Formely IMPORTKILLA35
LouBomb is offline
Old 01-17-2013, 01:24 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,785, Level 73
Points: 12,785, Level: 73 Points: 12,785, Level: 73 Points: 12,785, Level: 73
Level Up 84% Completed
Forum Activity 99%
Many of the too much/too little heat issues seen here are from the "blend door" sticking or it's actuator not working...
Instead of a valve to turn the hot coolant to the heater core on & off, most newer vehicles including the Focus just redirect the air between cold & hot (whether it comes in through the heater core or the A/C side).
Haven't played with this issue myself yet, but I've heard you can see the actuator & lever through the glove box area when you open that up all the way. Look for a lever & actuator on the air duct toward the middle of the car - you MAY see it try to move when you change temperature settings if it's just stuck and the actuator is trying to work. Some folks have reported having luck just freeing it by hand without it sticking on them again....
Luck with yours!
sailor is online now
Old 01-17-2013, 05:07 PM   #6
Wiplash2000V6
Fan#: 27480
also the temp gauge doesnt move. I didnt even think of the blend door thing. thanks .
Old 01-18-2013, 01:50 AM   #7
amc49
Fan#: 96610
Forum Activity 7%
Yes, my door shaft hole is stripped and I'm not pulling that box...........I simply made up a hook to open glovebox and hook the door to move it whichever way I need. Takes maybe 5 seconds to move it. The door actuator motor actually works fine, it just won't engage the door. For full heat you want the holes in the grille you see looking behind glovebox CLOSED. You want them open for max a/c.
amc49 is offline
