Gas pedal sticking at first - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-16-2013, 09:58 AM   #1
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,324, Level 29
Points: 2,324, Level: 29 Points: 2,324, Level: 29 Points: 2,324, Level: 29
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 0 smallblockfever Newbie
Hello all,
My gas pedal has started to stick in the off position.
Car is running fine and it still driveable.
The problem is that there's some notable resistance when pressing the pedal.
Once I overcome that resistance, I usually over rev the engine.
Nothing bad, just makes the car not very fun to drive, loud, and slippery (sidenote: of the 16 days this year, something like 12 have been raining here in Baton Rouge and the record for January is 14.94", and we're already at 13.5"...)
So spinning out (On accident of course) is a daily thing, often in a lot of gears.
Now I haven't done anything as of now to redress the problem, but it went away for about 30 minutes yesterday, and now it's back.
Has anyone had issues with this before?
any suggestions?
I plan on checking it out on saturday, what should I be looking for?
caught cables? spray some wd40? any help is appreciated.
smallblockfever is online now
Old 01-16-2013, 06:44 PM   #2
hopeitsnotjunk
Fan#: 103505
What I Drive: 03 focus svt
FF Reputation: 1 hopeitsnotjunk Good Standing Member
I have a 2003 mine has stuck a few times I find out if I push the gas peddle to the left it stops sticking I have not looked close but I think the bushings maybe bad
hopeitsnotjunk is offline
Old 01-16-2013, 08:51 PM   #3
D_Rock
D_Rock's Avatar
Fan#: 88378
What I Drive: 2004 SVTF Infra Red EAP
FF Reputation: 1 D_Rock Good Standing Member
This has happened to me, it's the bi-product of and emmisions function with the throttle body. There tends to be a bit of build up around the inner circumference along where the throttle valve meets it TB wall. In the cold weather the "sticking' is typically worse. Just pick up some throttle body cleaner (carb cleaner could work too, but I would stick to TB cleaner) and wipe down the inside of the TB paying special attention to where the valve meets the inside of the body, you may be able to see a line of residue that has formed there. It may take a more than one wipe down. Close everything back up and likely you'll be in good shape.
-Rock-
D_Rock is offline
Old 01-16-2013, 10:15 PM   #4
smallblockfever
Fan#: 95004
Sounds like a winning plan to me my friend! Thanks!!
Rock, You mentioned the word "emissions" but I couldn't pull a complete thought from what you were trying to say, so for lack of a better phrase come again?
Now I've been having 02 sensor trouble... Relative?
Old 01-16-2013, 10:36 PM   #5
D_Rock
D_Rock's Avatar
Fan#: 88378
Essentially stuff that should be brought through the TB and burned up isn't completely finished off and carbon and other gunk build up impeding the valve plate upon first movement from rest.
Your O2 sensor should have no relation as far as I can see. How many miles are on the car?
-Rock-
D_Rock is offline
Old 01-17-2013, 08:00 AM   #6
smallblockfever
Fan#: 95004
I passed 118k yesterday
Will that gunk affect it in every gear? Because it definitely does, however less and less as the gear increases
I.e. 1st is hard, 2nd is hard, 3rd is difficult, 4th feels sticky, 5th and 6th aren't too too bad
Old 01-17-2013, 12:33 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,338, Level 75
Points: 13,338, Level: 75 Points: 13,338, Level: 75 Points: 13,338, Level: 75
Level Up 22% Completed
Forum Activity 99%
D Rock's got the likely cause, crud that's sticking the throttle body plate when it's closed.
had to clean mine out last year for the same issue, "sticky" until it broke loose from the closed position...
as to the different gears, I'm guessing the sudden acceleration just isn't as noticeable in the higher gears. First is when you're more likely to REALLY accelerate more than you want when it breaks loose & opens more than you planned....
Clean 'er up & it should be OK!
sailor is online now
Old 01-31-2013, 07:14 PM   #8
choate
choate's Avatar
Fan#: 103130
What I Drive: 2006 maroon zx4
FF Reputation: 3 choate Good Standing Member
Confirmed. I had this same issue, read the sticky on here, cleaned the TB (simply with a damp rag then wiped dry several times. It cleared up my issue totally. Very annoying to JAM the gas accidently in any gear, much less when taking off. People used to look over at me like "do you even know how to drive a stick" lol. Now my take offs are like you're on air in that passenger seat lol
06 maroon ZX4 2.0 Duratec - MTX75
35% tinted windows - plasti-dip wheels & grill
lunchbox delete - stealth CAI w/ AEM filter
Team Duratec #29
choate is offline
Old 01-31-2013, 11:37 PM   #9
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Clean the throttle body.
jetrinka is offline
Old 02-02-2013, 10:58 AM   #10
glowedroid
Fan#: 102180
What I Drive: 2002 White ZX5
FF Reputation: 1 glowedroid Good Standing Member
+1 on the Cleaning of the throttle body, but if that doesn't help, there is a second thing to do:
I had your exact issue, and someone (I forget who) mentioned loosening the butterfly by the two screws, flipping it open and closed several times to "re-center" it and then tightening the screws again. Apparently, there is some lateral pull created by the spring on the side of the TB and over time, things wear and the butterfly migrates toward that spring (not really visible to the eye).
I did what they recommended (for the love of god do not fully remove the screws and drop them into the engine) and the problem went away 100%.
That was a year ago.
glowedroid is offline
