Installed new Oil Pressure Switch (2000 ZX3) still leaking oil ... - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2013, 02:33 AM   #21
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
Switch, no, use it again. Gasket? Maybe if it comes off clean and without de-laminating. I've done it before but condition of gasket is critical. Up to you, bud.
Teflon tape ALWAYS leaves shreds after use, those are the ones that cause the most trouble when you don't fish them out of hole and they get swept up in oil flow to block a small oil port like in cam supply galleys in head. You gotta be particular about the cleanout there. Seen torn up engines over it. Always leave the first two threads blank of tape.
Two layers or four, doesn't matter, the teflon is so flexible it simply squishes out of the space allowed. That doesn't mean you use ten layers though.
amc49 is offline
Old 05-13-2013, 06:36 PM   #22
AllenR
Fan#: 112259
What I Drive: 2006 light tundra
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 AllenR Good Standing Member
Thanks for the reply.
Is it okay to use that blue form a gasket stuff if I need to?
Local Ford dealer didn't have it in stock, so I had to order it. So, I rented a car. "Hyundai, Toyota, or 2013 Ford Focus?" he asked. Didn't have to think twice on that one! Rides good. Steering's a little odd, and the controls for a/c radio take getting used to. A little herky-jerky on the shifting, but as long as I put a moderate throttle, it shifts fine. It's got 25,000 miles on it. I'd buy a '13, if I was in the market for a new one. Is it just the 12's that had trouble with the shifting?
AllenR is offline
Old 05-13-2013, 08:25 PM   #23
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Well I checked all the posts for a particular type of trouble that I am going to describe:
Where was the engine made? Maybe it does not matter!
There are TWO types of threads here that WILL bite you in your rear
There is the 1/8" BSP or British Standard Pipe thread AKA 1/8" ISO
Then there is the more familiar 1/8" NPT or National Pipe Thread used in the Western Hemisphere [mainly USA] ONLY
The threads are different! The thread count is 27 per inch for one and 28 per inch for the other. AND if I have the actual count wrong it is still off by one thread
AND the flank angle on the NPT is 60 degrees with a theoretical flat on top and bottom
THE BSP has a flank angle of 55 degrees with theoretical round on top and bottom
I have been servicing high end instrumentation for 30 years. 25 years for Australian and 10 years for French. The kicker is components can and will come from any country including the USA so I HAVE to know threads
You need to go to the Ford dealer to get your stuff
mikeeshaq is offline
Old 05-13-2013, 09:20 PM   #24
AllenR
Fan#: 112259
Points 75, Level 1
Wow, didn't know that. Thanks, Mike. I bought the pressure switch and the gasket from a Ford dealer. The engine oil filter adapter is on order from the Ford dealer, as well, so I shouldn't have to worry about the wrong threads.
AllenR is offline
Old 05-13-2013, 10:59 PM   #25
mikeeshaq
Fan#: 72526
"""Wow, didn't know that. Thanks, Mike. I bought the pressure switch and the gasket from a Ford dealer. The engine oil filter adapter is on order from the Ford dealer, as well, so I shouldn't have to worry about the wrong threads. """
You will still need to fit the parts together at the dealership. Who knows maybe there was a thread change at some year [nightmare]
Whether NPT or BSP the threads are either 'tapered' aka 'pipe'
or parallel threads (straight or bolt) [not likely in your case]
tapered threads need to sealed by Teflon tape or paste also ask at the dealership , who knows maybe the truth is strange
However leave the first thread bare so you do not get Teflon shards into the engine oil system
Never ever use Teflon on parallel or straight [bolt]thread as the thread in NOT meant to do the sealing action but rather a gasket or a ferrule
The hose connections on a gas welding rig , usually use parallel or straight thread
Old 05-14-2013, 12:43 AM   #26
amc49
Fan#: 96610
Forum Activity 13%
'Never ever use Teflon on parallel or straight [bolt]thread as the thread in NOT meant to do the sealing action but rather a gasket or a ferrule'
If you only knew how many people I got in at the store that thought you could do that. I finally quit saying anything just to avoid the argument from an idiot. Sell him the tape or the more expensive sealer, it just adds to your incentive.................once I spent 12 hours rebuilding a multiple output gluer unit when the biker who fancied himself a killer mechanic did that on every one of like 100 fittings. We were scraping dried glue spots off the floor for a month.
The theoretical top and bottom flat or rounded irrelevent if the interference is at the sides as supposed to be. If bottoming on top or bottom then something wrong there. Thread cut too deep or worn. I HAVE seen some oddball tapered pipe fixtures that looked as if they were INTENDED to seal at the top with a gasket or o-ring though. Extra insurance maybe.
On our bike website some say same thing about the difference in Japanese (ISO) 1/8" pipe threads versus NPT, they say trouble screwing in NPT gauges into the engine boss. I never had any trouble and parts sealed fine without ever putting a tap to the threads. Maybe the joint just wasn't long enough to bring that extra thread into play. If aluminum then it might easily pull thread just enough to still seal. A .0013" error between 27 and 28 in each thread there.
What are we talking about here, 1/8" or 1/4"? My zetecs thinking 1/4" there?
amc49 is offline
Old 05-14-2013, 07:08 AM   #27
mikeeshaq
Fan#: 72526
Dear AMC
What are we talking about here, 1/8" or 1/4"? My zetecs thinking 1/4" there? """""
1/4 same diff STILL one thread off
I used to work on Atomic Absorption Spectrometers
These things use use Air, Acetylene and Nitrous Oxide
One mistake and it is death and injury
Caught a customer's maintenance people using Teflon tape on the acetylene hose fitting and it was leaking acetylene!!!
There IS a difference of fit between screwing in NPT into a BSP female fitting and vice versa
Actually screwing in a Parallel BSP into a tapered NPT works, cause then the O ring on the BSP parallel will seal. Assuming a smooth surface on the NPT end
Old 05-14-2013, 11:34 AM   #28
AllenR
Fan#: 112259
Points 75, Level 1
Well, I got the adapter and it looks like it has the tapered threads, but my sensor has straight threads. It begins to tighten after only a few turns.
If the numbers are the same, how do I get the right part??
AllenR is offline
Old 05-14-2013, 11:39 AM   #29
AllenR
Fan#: 112259
Points 75, Level 1
Dear AMC
I have a straight thread sensor, but no o ring. What should I do?
AllenR is offline
Old 05-14-2013, 12:26 PM   #30
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
What Elsolo said about permatex, i used the stuff when i was assembling the Detroit Diesel V6 engines where i work, permatex is AWESOME!
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
