Installed new Oil Pressure Switch (2000 ZX3) still leaking oil ... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2013, 01:57 PM   #11
AllenR
Fan#: 112259
What I Drive: 2006 light tundra
Points 89, Level 1
Points: 89, Level: 1 Points: 89, Level: 1 Points: 89, Level: 1
Level Up 78% Completed
FF Reputation: 1 AllenR Good Standing Member
Yeah, I thought that was a low torque setting, so I checked the manual again. It says 132 in/lbs. Divide it by 12 = 11 ft/lbs. I have a small torque wrench that will set to that, but the only 15/16" socket I could find was a 1/2" drive. It has min scale of 10, so I set it slightly above that. The specs came from a Haynes manual. They've always been right for me, but there is a chance it was wrong in the book. Is there a place where I could find the Ford recommended torque specs on all the engine parts?
What kind of tape should I use on the threads?
It looks like it may be dripping from the oil filter adapter, as well. I could get a new gasket for that, while I'm at it, or go ahead and get a new adapter if I need to.
AllenR is offline
Old 05-10-2013, 02:21 PM   #12
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,307, Level 75
Points: 13,307, Level: 75 Points: 13,307, Level: 75 Points: 13,307, Level: 75
Level Up 15% Completed
Forum Activity 99%
Can give ya a couple answers...
Teflon tape for pipe fittings is easy to use, just start the wrap back a thread or two so it isn't over the end. You wind it on opposite of the way it threads in, that way it's not trying to unwind itself as you start turning it in.
The "click type" torque wrenches aren't too accurate near the end of their scale, that's why you saw the in/lb number (that would be in the middle of an in/lb scale, and those are usually beam type). This is why I mentioned you'll likely need to "feel' it by hand.
Can't help with the spec. info., someone else might chime in on that eventually.
Cheers!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 05-11-2013, 02:57 PM   #13
AllenR
Fan#: 112259
Points 89, Level 1
Well, I wrapped it with teflon tape, and it still leaks. I guess the threads in the adapter are worn out. :( Bad timing at the weekend, too. Oh, well. Seems like there would be a gasket on the sensor to help seal it.
AllenR is offline
Old 05-11-2013, 03:12 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,580, Level 62
Points: 8,580, Level: 62 Points: 8,580, Level: 62 Points: 8,580, Level: 62
Level Up 44% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
try using a PTFE liquid. also clean out the threads with a brush. They also make some thicker sealant that is commonly used with motors that have two separate gaskets. GM has this that I know of (P/N: 4318083) that is suppose to be able to cure in the presence of oil and internal to the motor unlike normal RTV.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 05-11-2013, 04:45 PM   #15
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Why go looking for exotic sealants when like elsolo says, Permatex #2 non-hardening is perfect for this and does not really have to 'cure' to do so. It only thickens up as the VOC leeches out of it, which is perfect. If it doesn't work then you have a cracked mounting boss from overtightening, pipe thread does that easily with a heavy hand, since basically you are driving a wedge into part there.
Teflon here is a problem, I don't use any teflon based sealants except tape and that can cause trouble too. On pipe thread the increase in force ramps up way slower than on a normal bolt, that results almost always in overtightening by the unlearned, because there is no point at which the part seems to 'cinch up' like on normal bolts, or the feeling that bolt has pulled up tight. Pipe thread force just get steadily slightly higher and higher with no feeling of pulling up tight close to all at once, or what we have trained our minds to as being the right place to stop. Teflon being used aggravates that not pulling up factor, it is easier to crack parts with teflon used because the force pullup is even more gradual. In our shop back in the day we bought into the loctite new 'pipe sealer with TEFLON', after several cracked parts we dropped it and problem went away. D-mn stuff worked TOO well.
If OP has cracked it, try more sealer (not tape) and tighten LESS this time, less lets the crack close back up and might possibly seal. After that it'll be cleaning hole out super duper and epoxy part in with intention it can never come out again.
amc49 is offline
Old 05-11-2013, 04:54 PM   #16
amc49
Fan#: 96610
Forum Activity 40%
Bear in mind that any teflon thread tape can scrape away from the fixture to not seal, and most especially if you put it on yourself and wound it backwards. Hold fitting in your left hand and start the tape holding start with left thumb and wind it clockwise with the right hand. Line tape up when starting to miss the first two threads. No more than 3 wraps.
amc49 is offline
Old 05-11-2013, 04:59 PM   #17
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 38%
regardless of the sealant or how you due it, I would do it in the evening cleaning everything real good and then let it sit overnight with out using the car.
Hatch Nation #42
Old 05-11-2013, 05:18 PM   #18
amc49
Fan#: 96610
Forum Activity 40%
One advantage of physical tape is that it will simply move the oil out of the way, can be used with oily threads. Just a thought there. If using a semiliquid sealer then as he says, clean threads needed.
amc49 is offline
Old 05-11-2013, 05:22 PM   #19
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 38%
one thing i have found with the tape is the tape can (and if I am the only unlucky one) tape can be left in the threads. not sure if you get any double gasket effects if/when that happens...
Hatch Nation #42
Old 05-11-2013, 06:36 PM   #20
AllenR
Fan#: 112259
Points 89, Level 1
Wish this post was up before I started on it today. I busted the housing, exactly as you said. I couldn't feel it tightening up, and snap! there it went.
Oh, well. The housing was worn out anyway. The specified torque should have sealed it. I had put a new gasket on the adapter when I put the new switch in. Do I need to order a new switch and/or gasket?
AllenR is offline
