Special Tool Required for Brake Master Cylinder Replacement? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-16-2013, 01:07 AM   #1
focusgg
Fan#: 96641
What I Drive: 2005 ZX4
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 focusgg Good Standing Member
Hi All,
I need to replace my brake master cylinder on my '05 ZX4. The Haynes manual says I need 'special test equipment' to bleed the system after the master cylinder is installed on cars equipped with ABS.
Does anyone know what this special test equipment is, or how I can get around using it. Obviously, I want to do a proper job to ensure safety, but if there is a DIY trick, I'd like to know.
focusgg is offline
Old 01-16-2013, 01:13 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I imagine it would be a scanner or something like that to activate the abs solenoid? Hopefully someone else will chime in with the right answer.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-16-2013, 06:02 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
No, it's probably bench bleeding tubes. The master cylinder should come with directions on how to bench bleed it. You might also want a vacuum bleeder kit, but you should read the directions because bubbles in the lines on a vacuum bleeder are not a cause for alarm. It will actually pull air through the threads on the bleeder nipple.
Open up your new master cylinder and read the directions. Haynes Manuals are meant to confuse people and scare them into taking cars to a mechanic instead of actually giving customers technical knowledge of vehicles and systems. It makes the manual easier to write.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-16-2013, 06:56 AM   #4
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,381, Level 20
Points: 1,381, Level: 20 Points: 1,381, Level: 20 Points: 1,381, Level: 20
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 1 coldbear Good Standing Member
X 2 on the scary manuals.
coldbear is offline
Old 01-16-2013, 07:34 AM   #5
bennyfocus
bennyfocus's Avatar
Fan#: 50465
What I Drive: 2001 Blue Zx3
Points 1,215, Level 19
Points: 1,215, Level: 19 Points: 1,215, Level: 19 Points: 1,215, Level: 19
Level Up 15% Completed
FF Reputation: 6 bennyfocus Good Standing Member
No sleepyboy is right, on some occasions you may need a scan tool capable of bleeding the abs out. Personally I have only ran into that issue once or twice. Also something else I think they listed as "special equipment" is a pressure bleeder, I think they prefer you pressurize the master then crack open the bleeders. As long as you bench bleed the master before you put it on then bleed the system like you normally would on any other car you should be fine.
bennyfocus is offline
Old 01-16-2013, 01:19 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Forum Activity 2%
Unless there was a change between 2003 and 2005...
The service manual just calls out for traditional bleeding methods, nothing special or proprietary.
-Jar of brake fluid and a hose connected to the nipple at the caliper.
-Pressure bleeding from the reservoir
elsolo is online now
Old 01-17-2013, 12:23 AM   #7
amc49
Fan#: 96610
Points 3,374, Level 36
Points: 3,374, Level: 36 Points: 3,374, Level: 36 Points: 3,374, Level: 36
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Unless the ABS was activated during low fluid and swallowed air (should be impossible, but somehow people figure out how to do it!), then it is transparent to the system and normal bleeding should work fine. I would AVOID powering it on during bleeding if possible, only do it when necessary or forced............I know I never do anything special for it. Once you get air inside the ABS itself you are in much more trouble from what I've seen.
amc49 is online now
Old 01-18-2013, 10:28 AM   #8
bennyfocus
bennyfocus's Avatar
Fan#: 50465
Nah its not that bad, we had one come in from the body shop that they couldnt get a firm pedal in after a slight fender bender. They replaced the master twice and the booster before they brought it to us. We tried to bleed normally, then tried to bleed it with our power flush machine just to be sure there was no air. After that we did the abs bleed which as simple as selecting it from the functional test menu on our scan tool, keeping your foot on the brake pedal while it does its thing and after about a minute its done without the need to open bleeders or anything. Obviously though if you have no friends with access to a good scanner you will have to pay someone if it comes to that however I doubt you'll have any issues.
