bad svt problems!!!HELPPP - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 01-21-2013, 08:40 PM   #11
02svtf1326
Fan#: 76507
What I Drive: 2002 silver svtf zx3
FF Reputation: 1 02svtf1326 Good Standing Member
Originally Posted by tukaniSVT View Post
did you check the Cat?? I read you checked the VCT Solenoid, but the people here are suggesting you check your Cat.
Maybe, you should check that. Take it a muffler shop if you want them to check it.
Or if you have an OBDII Reader, unplug your cat and run your car for a couple of minutes. IT WILL BE LOUD ... but if the headers don't turn red, and all you get is the 2nd O2 sensor issue, then it's your cat.
And the code for the O2 sensor would be because you would be doing this test with out the cat in.
Ray
Tom said if it was the cat it still would start normal!??? This Sucks lol
Hatch Nation #31
02svtf1326 is offline
Old 01-22-2013, 01:39 PM   #12
02svtf1326
Fan#: 76507
Bump.....anyone have an idea?
Hatch Nation #31
Old 01-22-2013, 01:42 PM   #13
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
last time my header glowed red hot was because of the IACV being stuck open.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 01-22-2013, 02:14 PM   #14
02svtf1326
Fan#: 76507
Was it hard to start also? Mine will turn over for about 10 seconds before it actually fires up! How would i fix it if it is sticking?
Hatch Nation #31
Old 01-22-2013, 03:32 PM   #15
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
take it off the intake manifold and clean it.
also your hard starting could be your battery how old is it?
Old 01-22-2013, 03:50 PM   #16
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Things that would make it hard to crank and make the header glow at idle
To little fuel or to much fuel ( this can be checked with a fuel psi gauge and a scan tool)
To little or to much ignition timing ( this can only be checked with a scan tool)
Cam timing off ( this can be checked by setting the cams and #1 Cly like your going to install a new timing belt )
Vac leak but this would also cause a very high idle , like above 2500rpm (this can be confirmed with a scan tool or checking every vac like for issues , this I do not feel is your issue)
I have never seen a CAT cause a hard cranking or a header to glow until you put a load on the engine
I think he is either running very lean , overly rich and burning the fuel in the header(rare) or has a valve open when it shouldn't be from cam timing issues , these are the most common then it gets complicated
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 01-22-2013, 09:28 PM   #17
02svtf1326
Fan#: 76507
I will have to check into these! Thanks! And my battery is new...it doesn't turn over slow it just takes awhile to fire up! Would a blown intake gasket cause any of this?
Hatch Nation #31
Old 01-22-2013, 09:30 PM   #18
02svtf1326
Fan#: 76507
I heard that maybe a cracked block could also cause similar issues?
Hatch Nation #31
Old 01-23-2013, 12:05 PM   #19
1turbofocus
FF Affiliate
Fan#: 1123
I cannot rule out a blown intake gasket because that would cause a Vac leak , very right rpm when it did start but wouldnt think glowing headers from an intake leak
I have a few questions and would be easier to phone can you give me a call this evening
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 01-24-2013, 03:42 PM   #20
02svtf1326
Fan#: 76507
What number can i reach u at later?
Hatch Nation #31
